Rotax hub adapter
Airboat propeller discussion.
zion
Rotax hub adapter
Post by zion » Thu Jun 02, 2016 10:41 am
Found a great deal on a warp drive prop. It has a 75mm rotax bolt pattern. My retrieve has a 1" keyed shaft.
Where can get a hub adapter to convert the hub? I contacted warp drive. Seems I wasn't buying a new property didn't interest them. I'd rather buy one on the Web than have one made locally.
ZZ
PeaRiverOpossum
Re: Rotax hub adapter
Post by PeaRiverOpossum » Thu Jun 02, 2016 11:24 am
Might check barnstormers site
Sent from my SM-N920V using Tapatalk
zion
Post by zion » Thu Jun 02, 2016 12:09 pm
PeaRiverOpossum wrote:Might check barnstormers site
That's where I got the prop. Guess I could put in a want add for one.
PeaRiverOpossum
Post by PeaRiverOpossum » Thu Jun 02, 2016 2:05 pm
You may be time and money ahead to just have one made. It wouldn't be hard to build one either if you have a welder and drillpress. Your just going from a 1" keyed shaft to a rotax hub? You could also get a sprocket from surpluscenter.com. Just drill your holes, weld sprocket to hub and you're in business for less than $20.
$5.65 for Hub
http://www.surpluscenter.com/Brands/Con ... 2343-I.axd
There is a multitude of weld-on sprockets for less than $10
This one is $7.20.
http://www.surpluscenter.com/Power-Tran ... 981-17.axd
If you don't have a welder you can also get one already built. They all you have to do is drill your holes to match the hub. Just pick the OD of the sprocket.
This one is pretty big
http://www.surpluscenter.com/Power-Tran ... 3-60-E.axd
zion
Post by zion » Thu Jun 02, 2016 2:39 pm
Thats a great idea.
PeaRiverOpossum
Post by PeaRiverOpossum » Thu Jun 02, 2016 2:41 pm
zion wrote:The picture of this must no be to scale or probably is a different one. There is not enough space in the sprocket for bolts unless the holes were tapped.
[/quote]
Stock pic/ All the pics are the same. You can click on the scaled drawing to see all the dimensions
OR here
http://www.surpluscenter.com/Catalog/Catalog289-135.pdf
zion
Post by zion » Thu Jun 02, 2016 2:49 pm
I found it. I can make that work
thanks
OR here
http://www.surpluscenter.com/Catalog/Catalog289-135.pdf[/quote]
PeaRiverOpossum
Post by PeaRiverOpossum » Thu Jun 02, 2016 2:53 pm
NP. Surplus center is a gold mine. Post up some pics when your done.
zion
Post by zion » Thu Jun 02, 2016 2:55 pm
I love this web site. It has lots of goodies.
http://www.surpluscenter.com/Engines/En ... 8-1903.axd
Return to “Prop Talk”
