Prop choice GPU 220
Airboat propeller discussion.
Hjbjzj
Prop choice GPU 220
Postby Hjbjzj » Fri Jun 24, 2016 7:41 am
Hey everyone,
I currently have a 14' gilileo with 4 seater rigging (heavy boat/heavy rigging). It has a gpu 220 that is currently being rebuilt. It will be receiving a dual mag upgrade and o470r pistons.
Also the boat was spinning a 74" signature series prop at 2950 rpm at pitch Mark 2.
The boat pushed ok. I'd get stuck in really thick heads of saw grass. I'll be adding a grass rake to help. Ran nice in open water. Cruised at 30mph at 2300rpm. Topped out 40 mph.
I am considering a new prop and I'm looking purely for push. I don't want to be the only boat not making it to camp. 150 yards of a dry.
Thanks
Justin
scottyroll
Re: Prop choice GPU 220
Postby scottyroll » Fri Jun 24, 2016 7:54 am
It looks like you are propped right but too heavy.
No prop can fix that.
:Scotty-Roll:
FLAwless
14ft Laser/6.0 LQ4/2.37 Rotator/3 Blade "K"
schmidtav2
Site Supporter - VII
Postby schmidtav2 » Fri Jun 24, 2016 8:05 am
For push, in my opinion, you will be hard to beat a Sensenich NGQ 2 blade 74" diameter. The next best option would be a Whirlwind Whisper Tip 2 blade 74" diameter.
Tom Schmidt
Schmidt Aviation
giggit
Postby giggit » Fri Jun 24, 2016 8:12 am
X2 on the whisper tip
Call Patti at Whirlwind Propellers!
619) 562-3725
Excellent service that cant be beat...JMO
14.5 Scorpion O520
jeepinocala1111
Postby jeepinocala1111 » Fri Jun 24, 2016 8:18 am
Hjbjzj wrote:Hey everyone,
Thanks
Justin
Hands down 72 ngq if it's a 220 72 is all you need and I found the ngq to push the best. Now if you have a conversion 220 with 470 jugs then I have no idea.
Postby kwanjangnihm » Fri Jun 24, 2016 8:20 am
Justin are you blocking clean air flow to the prop with the seat and cage setup?
A 74" sig typically has good push, but I'm wondering if it's spinning higher due to blocked air?
Have you pitched it down to 2700-2850 range? Also are you running poly or slick bottom?
:rebel:
Hjbjzj
Postby Hjbjzj » Fri Jun 24, 2016 8:53 am
Boat has poly. And a full cage. I have not pitched it to the 3 Mark yet. If I figure how to upload a pic I'll do that. But I believe that there is plenty of airflow to the prop. I could be wrong. The motor was very healthy till I ran her low on oil.
Would a prop that comes into power quicker be any better? For instance like a Saber, razor, or excalibur?
Hjbjzj
Postby Hjbjzj » Tue Jul 05, 2016 6:11 pm
Any more opinions on the matter? Considering buying the NGQ or excalibur.
Postby Deano » Tue Jul 05, 2016 7:37 pm
I agree with kwanjangnihm, in that you have some heretofore unidentified complication. There are many 540s
and a couple Cadillacs running around on bigger hulls that don't act like what you are describing.
I do not have a different prop recommendation for you, but I would keep putting pitch in it until you are only turning about 2750 as was suggested and see how it acts before I went prop shopping.
If your cage and/or something else is severely hampering the prop's ability to get a clean bite of air, no prop is going to perform like it was designed to
jeepinocala1111
Postby jeepinocala1111 » Tue Jul 05, 2016 8:41 pm
Hjbjzj wrote:Any more opinions on the matter? Considering buying the NGQ or excalibur.
Got with the ngq 72" perfect prop.
Hjbjzj
Postby Hjbjzj » Tue Jul 05, 2016 10:46 pm
I'll wait till the boat is all back together. Ill add more pitch to the signature series.
Appreciate the input everyone.
Return to “Prop Talk”
