R series Sensenich Prop
Airboat propeller discussion.
hillbilly airboat
Postby hillbilly airboat » Sun Aug 21, 2016 10:20 pm
I am looking for a the R series Sensenich 2 blade prop, I have the I beam Sensenich and it seems to be to much prop, I have the 290 HP Crate engine it does pretty good but Sensenich guys say the R series 2 blade will do awesome
406 JAMIE
Re: R series Sensenich Prop
Postby 406 JAMIE » Sun Aug 21, 2016 11:50 pm
i had 330hp gm crate iron heads with 2.12 box turning a 79inwide whisper tip ex blds were 12 in wide when i got those blds made a whole different boat like nite and day.hope this help.besafe y all :rebel:
Postby SWAMPHUNTER45 » Mon Aug 22, 2016 6:52 am
It sounds as if he has "S" blades on it now and is looking to obtain "R" blades.
The "S" are 16 inches wide and that is a lot of blade for a 290hp engine to spin.
H-B if you post a little more info you may get some feedback or someone interested in a trade.
The classified section has an area for both props being sold and items to trade.
DIBBS7J
Postby DIBBS7J » Mon Aug 22, 2016 3:34 pm
I'm running a stock Efi 5.3 and 2.37 rotator turning a 81.5" 2-blade R and I'm very happy with my performance
14x8
5.3 Efi Rotator 2.37 82" sensenich 2-blade R
It is what it is
Postby kwanjangnihm » Mon Aug 22, 2016 4:30 pm
DIBBS7J what is your WOT, blades pitched at (mark or degrees) and cruise info? Thanks!
:rebel:
Postby Deano » Mon Aug 22, 2016 6:33 pm
kwanjangnihm wrote:DIBBS7J what is your WOT, blades pitched at (mark or degrees) and cruise info? Thanks!
:rebel:
:shock: Be careful there, my A/C friend . . .
you're starting to sound like you're running a water pumper. :lol:
For whatever reason . . . if you are seriously weighing that information,
it is worth noting at the same time that Dibbs7 is running an eight foot wide beam. :)
DIBBS7J
Postby DIBBS7J » Mon Aug 22, 2016 8:16 pm
5000 wot @17* cruise in deep water is 3000-3400 depending on weight I have at the time..
This seems to be a happy middle ground for my setup but I have run it 4600 wot @20* 2600-3000 it's a lil more sporty at 17* though..
and yes 8' beam makes a world of difference I had a 220 gpu on a 12x7 then on the 14x8 with the same rigging and same old 220 it was night a day difference
14x8
It is what it is
DIBBS7J
Postby DIBBS7J » Mon Aug 22, 2016 8:19 pm
14x8
It is what it is
Postby kwanjangnihm » Tue Aug 23, 2016 6:05 am
Deano you know I always gotta keep my bag a tricks full for those CM guys!! :toothy7: :stirpot:
A - always
S - seeking
K - knowledge
:rebel: :thumbleft: :salute:
Postby One Eyed Gator » Tue Aug 23, 2016 9:54 am
I run a 5.3 carbed with 2:1 and turn 81.5" 2 blade R at 5100 just past mark 1. Cruises at 3200 deep-water loaded for redfishing with 3 adults. Have well over 400hrs between 2 boats. I have always had goodluck dealing with Sensenich.
Pushes my 14'x7-6 alumitec fairly well.
Return to “Prop Talk”
