5 blade on caddy
Airboat propeller discussion.
john1edwards
5 blade on caddy
Postby john1edwards » Tue Sep 20, 2016 8:36 pm
anybody running a 68 5 blade on a caddy 472/500? direct drive
Just an Orange Engine, Nothing Fancy . Proud to be an American
Re: 5 blade on caddy
Postby Deano » Tue Sep 20, 2016 10:06 pm
Used to be that '5 blade' automatically implied Warp; not so anymore. What kind ?
68 sounds short to me, but I guess that could depend on what kind of blades they are.
I prefer wide blades, but there is no denying how successfully Sidejobs ran a 72" 4 blade Excalibur. Image
Striker543
Postby Striker543 » Wed Sep 21, 2016 8:05 am
If you're talking about a warp drive or a saber/razor, I don't think that would be enough prop. I prefer something between 72" and 74" on a caddy, preferably a two or three wider blade prop.
badge01
Postby badge01 » Wed Sep 21, 2016 12:14 pm
Agree with Deano, it helps that he knows Caddy engines also, it isn't a junkyard pull..... I had an 8 blade warp that I alternated pitch, 4 high 4 low, worked real well, basically stock motor, common build ups like intake plenum, roller rocker shaft, etc. wasn't a hill climber but I never got stuck. no a lot of dry runnin here in NW Florida.
do it right or dont do it at all!!
12' airgator 500 caddy DD 8bld warp drive
john1edwards
Postby john1edwards » Wed Sep 21, 2016 9:51 pm
I have caddy boat project and just happen to have a 68 five blade, but was told that due to hermonic balance insues six was better and am sure longer would be better.
john1edwards
nebraskaairboater
Postby nebraskaairboater » Thu Sep 22, 2016 9:06 am
if you already have the prop bolt it on and give it a try before you spend money on a different prop.
Dan Porter, Jr.
Fremont, NE
16 x 8 1971 Flat Bottom Fiberglass Hull / 500 Cadillac/ 2.12:1 Rotator / 80" 3-Blade Sensenich S
Return to “Prop Talk”
Users browsing this forum: Bing [Bot] and 1 guest
