What is best size prop for PE60?
Airboat propeller discussion.
DHoneycutt
Postby DHoneycutt » Wed Oct 26, 2016 9:03 pm
I just got my first airboat and it has a PE60 on it with a 72 inch 2 blade prop was told its the wrong prop not to run it so I don't damage the motor. Was told the boat will not get up on plane that it needs a smaller prop any thoughts or suggestions
Southern_Son91
Re: What is best size prop for PE60?
Postby Southern_Son91 » Wed Oct 26, 2016 9:45 pm
First off congrats on the first Airboat. My first boat was a 10 ft. Baby gore with a pe60 on it. I had a very small (60 inches or so) 4 blade warp drive and that boat would honestly surprise people where it would go. That motor was only rated at 90 hp new. I would call whirlwind and talk to them about there props for "mini's" . Good luck finding a prop.
200 HP 4 cylinder 320 with 480 angle valve jugs, nitrous,and the balls to drive it right.
if your not living on the edge your taking up to much space.
Bob1120
Postby Bob1120 » Thu Oct 27, 2016 9:06 am
My first boat was a franny with a pe 60. It had dual mags. I turned a 60x28 between 2900-3000 rpm. The boat ran amazing. Some of the guys swore by the 66x26 never had a chance to run one though. Good luck with your boat. Keeping it light is the key!
FastrackBAW
Postby FastrackBAW » Sat Dec 10, 2016 12:23 am
Here's mine, pe60
viewtopic.php?f=85&t=68362
Running a Sensenich 60x32 wood/composite
The guy that propped it and built it is an aircraft mechanic. He said the it's turning in the correct rpm range which I'll know once I install my tach :)
I would think 72" would be too much prop. But the pitch factors into it as well.
Ben
Return to “Prop Talk”
