anyone running a 4 blade sensenich JX 82"
Airboat propeller discussion.
stickittoem
Postby stickittoem » Fri Jan 06, 2017 5:17 pm
Just curious for any comments on the prop performance/motor set ups related with the jx. pitch marks, hp, cruising speed, pros, cons...anything. shoot
Re: anyone running a 4 blade sensenich JX 82"
Postby SWAMPHUNTER45 » Sat Jan 07, 2017 8:56 am
I would like to see one of the 4 blade JX set ups on a big (18ft) heavy boat not a mid size as well as the new Torque gear drive.
The little I have seen on FB sure looks a lot like a Whirlwind and the chatter is they like higher blade speed.
Hear a lot but haven't seen a one in the field as of yet.
stickittoem
Postby stickittoem » Sat Jan 07, 2017 10:35 am
I just ordered it and was curious on peoples input across the board....if i dont like it then ill just sell the prop and get a different one. I am having a boat built (18x8) with all the bells and whistles so it will be on the heavier side....although i went with an all aluminum BBC and was told it shaved about 150 pounds so that prob makes up for the extra decking etc.
stickittoem
Postby stickittoem » Sat Jan 07, 2017 10:36 am
i think you may have chimed in on my last post
Return to “Prop Talk”
