Prop adapter
Airboat propeller discussion.
MaxxForce
Prop adapter
Postby MaxxForce » Tue Aug 29, 2017 9:07 am
Looking for a prop adapter for a 4A084 if anyone has one they would like to get rid of.
DONT RETREAT JUST RELOAD!!!
WhirlWind Propellers
Re: Prop adapter
Postby WhirlWind Propellers » Thu Mar 01, 2018 7:40 pm
Hi MaxxForce,
Did you ever find an adapter for you 4AO84 engine?
I typically see these engines with a special build reduction unit (Circle S Mfg or ArrowProp) that gives you a 1.69-1 ratio so you can turn 3600 RPM to get the max 40 HP without overspeeding the propeller. With the 1.69 reduction, we recommend a 3-blade Razor X Mini propeller in 65" diameter.
Sincerely,
Patti
:proud:
MaxxForce
Re: Prop adapter
Postby MaxxForce » Thu Mar 01, 2018 8:23 pm
Yes I did get a prop adapter from arrow prop, I am going to run it direct drive do you sell a prop that will work on this engine DD?
Re: Prop adapter
Postby WhirlWind Propellers » Thu Mar 01, 2018 8:50 pm
MaxxForce -
Do you have any diameter limitations? Do you know what bolt pattern Arrowprop put on your prop adapter?
Sincerely,
Patti
:proud:
MaxxForce
Re: Prop adapter
Postby MaxxForce » Thu Mar 01, 2018 9:08 pm
I don't have any diameter limitations, not sure about the bolt pattern as I don't have it here in front of me it's at my work I'll have to look tomorrow.
Return to “Prop Talk”
