76 stump puller or 75 3 blade h
Airboat propeller discussion.
cycoles
Postby cycoles » Tue Nov 14, 2017 8:18 pm
which prop has more push
13'5" wide nose gileo 220 gpu 5 blade warp , old caddie puller
Prototype
Re: 76 stump puller or 75 3 blade h
Postby Prototype » Tue Nov 14, 2017 8:38 pm
Freakin legalities are so bad now days that it's almost hard to post opinion.
IMO a 76 stump puller will out push a 75 3 blade h! The balance will give you fits trying to put a single stump puller on a boat though.
I sure hope this wasn't a compare to a 3 blade 76 stump puller vs a 3 blade 75 h?
That's about a 100 hp on the northern end of pitch and props even with a 2 to 1.
pontoon outlaw
Postby pontoon outlaw » Sun Dec 17, 2017 8:03 pm
cycoles wrote:which prop has more push
I use a 76 two blade stump puller with my cad 507 with a box@151-1
Sent from my E6833 using Southern Airboat mobile app powered by Tapatalk
WhirlWind Propellers
Postby WhirlWind Propellers » Thu Mar 01, 2018 5:48 pm
Hi Cycoles,
What engine were you wanting to put the 76" Stump Puller on, and how many blades? Is this for your 220 GPU engine?
I can recommend a few options for max thrust on the 220 GPU. (Sorry if this is not the engine you are asking about)
1. Excalibur 3-blade in 72" diameter ($1790)
2. Whisper Tip Narrow 2-blade in 72" diameter ($1690)
3. Whisper Tip Narrow 3-blade in 68" diameter ($2290)
And if you were looking at used propellers, some of our older blade styles that would be good for the 220 GPU:
*I'm always happy to look up history on a used propeller if you are looking at one for sale.
1. Super Snapper 2-blade in 72" diameter
2. Super Snapper 3-blade in 68" diameter
Sincerely,
Patti
:proud:
Return to “Prop Talk”
