J Series Experience & Updates
Airboat propeller discussion.
Post by kwanjangnihm »
Waterthunder wrote: We tested 3 different blades back to back to back with the same air temp, humidity and corrected altitude - the proto type blade made more thrust in a 3 blade configuration than the 4 blade R did
Should we assume the proto type is now the JR blade, or did the new JX blade make more thrust than the R?
Waterthunder wrote: The real interesting part is the proto 3 blade and 4 blade NGR had the same pitch to stall at 5,500 so that gives you an idea how much more efficient the new blade is. It uses less area than a 4 blade but the same pitch and produces more thrust
Same question as above: is this the 3 blade JR or JX outperforming the 4 blade NGR?
In each scenario, the 3 blade proto outperforms a 4 blade counterpart.
Does anyone have any feedback or experience with the J series to comment on this performance information?
Has anyone actually lost a blade and gone to a 3 blade from a 4 blade setup?
loudmouse
Re: J Series Experience & Updates
Post by loudmouse »
4 blade JX here and I wouldn't change it. That coming from a 3 blade NGR. The NGR is agreat prop also. Jus Sayn! Luv me some JX at 800hp on its ass will push hard down low and fly up top.
Built and Tuned by Me
BluByU2
Post by BluByU2 »
Well, I'm going to find out how well a 3 blade 80" JX setup will work on my rig because I plan on ordering it this week.
loudmouse
Post by loudmouse »
If u have over 500hp I don't think you will be disappointed. I also am a believer in prop rpm over pitch unless your boat is a tractor and not concerned with speed.
wes30
Post by wes30 »
I couldnt be happier with my 80"jx 2 blade,,,450hp sbc 237 box ,,pitch set on 20degrees goes anywhere i want with my 4 people family
WES what are the degree ranges with that hub?
Is 20 pitched hard ?
wes30
Post by wes30 »
I believe 8 to 30
loudmouse
Post by loudmouse »
Not real sure how the sticker relates to actual degrees but it appears the 20 mark is relevant to the old way of the 2 mark. Should be the sweet spot for both pitch and rpm with a 2.38 box.
Wes, what is your cruz rpm with the 2 blade if ya don't mind sharing that?
wes30
Post by wes30 »
At 20 degrees im turning 5200 rpm wot ,13'6 hammant ,im cruising right around 3100 with 4 people deep water or course
loudmouse
Post by loudmouse »
I prefer a good balance of low cruz rpm, low rpm push, high rpm push and top speed. Sounds jus like the way you have it set. If you changed it what you gain in the upper rpms you will loose on ur cruz rpm which is where 50% of the run time is anyways. It would be good info to change ur setup to a 3 blade with ur box a 2.55 and a 2.68 and compare numbers with ur hp for the JX. I would like to know if 400/450 hp would give good numbers with the JX 3 blade. I know the 3 blade NGR works well with that hp range.
wes30
Post by wes30 »
Yes would definetely like to find out
BluByU2 wrote: Well, I'm going to find out how well a 3 blade 80" JX setup will work on my rig because I plan on ordering it this week.
Blu any updates on your new JX setup? Interested to see how it performs compared to your old prop!! :salute:
loudmouse
Post by loudmouse »
:shock:
redfishrascal
Post by redfishrascal »
I have 3 blade 82" JX with alittle over 500hp SBC and love it.
redfishrascal
Oh and a 255 OX Box
keebo
Post by keebo »
I don't know about the carmotor J-series but I just put a 2 blade 76" JW on my AV540 and that sucker will hunt.
Set @ 14 mark turning 2750 with a cruise of 1500 in skinny and 1700 otherwise, great match for the AV 540.
:old_glory: :florida: :GA:
Return to “Prop Talk”
