What is the best pitch to set the blades at I have a 60/41 wood prop as of right now going to pick up the warp drive after work today. Also is 60 to short? My wood prop let's me run dry no problem would it be better? The same? Also I'm in lake county florida
The pe90 is bored .15 over also
5 blade 60in warp drive on pe90
- Southern Airboat Member
Re: 5 blade 60in warp drive on pe90
I am running a PE90 but it has the 520 cyl on it. I have a 67" 5 blade on it pitched at 8 deg. mine runs dry really well. extremely snappy.
as far as the difference in prop you will probably loose some low end push. but the snap of the warp is great just have to feed it more throttle. your speed will pick up a bit though.
