70” or 72” WW on a 220
Airboat propeller discussion.
CypressHunter
Post by CypressHunter »
Currently run a 70” water walker on a 220 13’6” cottonmouth. Just wondering what I’d gain or lose swapping hubs and going to a 72”
mojoe
Re: 70” or 72” WW on a 220
Post by mojoe »
If you swap them out, you will say it has better low end push but you lost a little snap. If somebody swapped it out and didn’t tell you, you probably wouldn’t notice anything different.
Mark 7:9
CypressHunter
mojoe wrote:If you swap them out, you will say it has better low end push but you lost a little snap. If somebody swapped it out and didn’t tell you, you probably wouldn’t notice anything different.
So nothing? Lol
AirHog
Post by AirHog »
I would choose the 72 for mor push.... plus if you modify the engine with Aircraft cylinders even 0470 cylinders would be better off with the 72”
Good Luck
AirHog
CypressHunter
AirHog wrote:I would choose the 72 for mor push.... plus if you modify the engine with Aircraft cylinders even 0470 cylinders would be better off with the 72”
Good Luck
AirHog
I am about to go thar route or 520 :shock:
Post by John Fenner »
I put a 74" whisper tip on a 10:1 220/520 conversion, very impressive machine!
Return to “Prop Talk”
