Airboat Prop
Airboat propeller discussion.
tonylane
Airboat Prop
Post by tonylane »
Hello I'm new to air boating. I bought a 12 foot by 8 foot Fiberglass hull with a 1/4" polymer plating on the bottom. It had a 305 chevy engine with a 66" x 34 wooden prop on it. I'm putting a 5.7 mercruiser 350 chevy marine engine in it with 260 HP. What prop should I use. It's a direct drive. Thanks
Striker543
Re: Airboat Prop
Post by Striker543 »
I would find a used 68” or 70” composite prop rather than buying a new wood prop - you will get more for your money. Also chances are your engine is not making 260hp at 3,000rpms, which is the max rpms you should turn a prop (I am assuming you are direct drive based on the prop you currently run).
Re: Airboat Prop
Post by kwanjangnihm »
tonylane welcome to SA! :salute:
Striker hit the same points I had in mind. (lower hp at ~2800-3000 rpm)
Here is an older thread with some pro's & con's using this platform.
viewtopic.php?f=48&t=62864&p=611802&hil ... er#p611802
Good luck with whatever you decide.
tonylane
Re: Airboat Prop
Post by tonylane »
Thanks guys helped a lot The marine engines are built to have more torque at lower RPM'S what I'll do is figure torque and HP at 3,000 RPM and go from there.
WhirlWindProps
Re: Airboat Prop
Post by WhirlWindProps »
Our CarbonMax Narrow 72" propeller is pefect for that engine. Feel free to call in for specific questions: 619-562-3725
https://whirlwindpropellers.com/airboat ... 72-narrow/
terrible ted
Re: Airboat Prop
Post by terrible ted »
I would use 4 0r 6 blade warp or similar on a standard small block dd. I say it was better balance on my old dd small blocks, but 2 blades work just I think there a little harder on the crank.
Return to “Prop Talk”
