Boy this rabbit hole is really deep!
Ruagatr
Re: Boy this rabbit hole is really deep!
Post by Ruagatr »
Look great. Building our palm beach hull was the greatest thing my son and i have ever done together. Made us understand the real science of hulls..... Congrats!
Maddog
cuban cracker
Post by cuban cracker »
Got to do a little work today so here it is.
Started by squeezing the sides together with a handy dandy pipe clamp.
Once squeezed in place and where I wanted it, I clamped it with vice grips, drilled the hole and hand tight for now.
Finished look after everything has been tightened in place.
Tomorrow road trip for some metal to place my horizontal and a pair of triangulations. :thumbright:
I took the RED PILL and am staying in wonderland to see how deep the rabbit hole goes!
And boy is it deep!
yobee
Post by yobee »
Love it. Keep it up man.
Larry
Post by Larry »
Looking good, I am at the same step on rebuilding my hull. It was a full deck and I am redoing all the metal stucture making it a 3/4 deck with a 2ft bow cap and 12" walk arounds. Also used 2x3 angle on the side instead of the 1" it had so now the boat is 2" deeper all the way around :)
goldhunter_2
Post by goldhunter_2 »
looks good ............. if you can just get your helper (glades cat) to stop slacking off you'll be done in no time..lol
:rebel:
cuban cracker
Gladescat! Who the hell is that! Couldn't recognize him if he wasn't standing in front of me. LOL :lol: :lol: :lol: :lol: He'll be there, its just my fault not giving ample time. So with that being said here is what little ol me did today.
Started to complete the bulkhead. Had to go tool up and made a push out ram to align the top bar of the bulkhead with the deadcenter of the boat.
Dead on the money. Not as bad as I thought again.
Once aligned I put a triangulation bar in place and locked it in place. Then I put my vertical bars in place as well.
Here is the end result and now i'm ready to do the back bulkhead and hopefully sheet the deck by October - early November.
And boy is it deep!
witchcraft
Post by witchcraft »
Looks like you have it going your way . very nice1
Bet your wife and neighbors want it finished sooner than you do.
Keep up the good work.
" Beware of the Old Man in the Black lawnchair. If you out run him, he will chase your A$$!"
Whitebear
Post by Whitebear »
Just jam up man ! Jam up !
akblackdawg
Post by akblackdawg »
Looking good, really nice job and workmanship. Ignorant question here, not at all use to seeing skinny little boats like that. With the bottom as rounded as it is, how will the boat perform? Does that make it slide better? Can't imagion it would slide better. Just trying to learn more about design of boats. Bud
cuban cracker
Did a little work today and finished up the rear bulkhead. Now getting ready to lock the transom in place to the runners and build the engine supports next. Off to the yard to get more material. :thumbleft:
And boy is it deep!
cuban cracker
Today I would like to teach some spanish. "me entro la furia!" Translation: Fury took me over! Got tired of fiddle f!@#ing around with the runner to get them from this
and finally tried something new to get to this
an hour later + -.
After that I moved to the stern and put in my gussets and hopefully this week I can get started on the framing so that I can deck her over already.
And boy is it deep!
Cherpa
Post by Cherpa »
Drain holes, bilge pump, gas tank. Then deck over.
We grow too soon old and too late smart.
cuban cracker
Cherpa thanks for the order of things. Sometimes being under so much frustration u loose sight of how things should get done. After I frame I will get with u for the tank builder.
And boy is it deep!
Cherpa
Post by Cherpa »
Try calling Dave Powell's tank service. 386-690-4770. This is not a local number, but he builds custom gas tanks & rudders.
cuban cracker
Got alot done today even with the rain. She is ready to have a tank built and start decking.
Back to buy some more sheets and start designing my nose and rake.
And boy is it deep!
Ruagatr
Post by Ruagatr »
How did you straighten/level the runners at the front when your fury took over?
Maddog
cowtown
Post by cowtown »
any jacks going in ? ,
http://usfth.tripod.com
And Proud Of It !!!
cuban cracker
Ruagator on the t-bar themselves when the bent to form the curve a dimple forms. With a bucking bar and the gun you work the runner on the port and starboard side of each runner starting from the back moving forward towards the bow. IMO this could of been avoided by making sure that the runners were bent more even or actually even is better. I am convinced that u can bend them to be extremely close because I did it to the 3 bars at my bow. All I bent dead on and they are just as thick as my runners. So I feel a better more even bend would have saved me alot of grief. As to the jack question for now no I don't think this boat needs one.
And boy is it deep!
cuban cracker
Started the motor stand and here are some photos of what was done.
Getting the boat itself leveled out to start. Shimmed with cardboard work just fine never moved an inch.
Hanging the motor a coke can long and coke can wide from prop to deck.
Plumbing the motor itself. Tricky to get the plums on the center case but got'r done.
Started to weld. Its coming around.
Starting to take shape. Nice to see a project to start coming around.
Finished motor stand. Round tube is sure not the way to go for the first time around. But I like how it looks better than square, not bad for the first time.
Now to start decking the boat. :thumbleft:
And boy is it deep!
yobee
Post by yobee »
Hey brother, build your rig before you deck it, so you dont get your decks all scratched up when your building your rigging. Looks awesome though, I was thinking about this boat just the other day!
cuban cracker
Yobee thanks for the advice. Makes sense to me. Hopefully I can get started on that soon.
And boy is it deep!
Striker543
Post by Striker543 »
Was wondering how this build was going the other day. Great to see it coming together. Looks great!
outlaw38
Post by outlaw38 »
Looks great. Thanks for the build along
18x8 Air Ranger, ZZ502, CH3 2.3 to 1 reduction, 80" Master Blaster 3 blade prop, 3/8 Poly bottom and sides rivited
bruceharwell
Post by bruceharwell »
CC, Not for nothing, but we always webbed the main angles fore and aft that the engine mount bolts to. In other words, a filler panel from the transom to the rear bulkhead. Riveted or bolted from the runner to the large angle. Better support for the engine and a more durable hull overall. You've done a fine job here. Very time consuming but something to be very proud of for many years. :salute: :thumbleft:
SwampNinja
Post by SwampNinja »
Hey. Been following tyour thread. Looks good man. Gotta hit me up when its done. I live in Davie but grew up down there. Would love to ride with you guys and meet the infamous Cuban Cracker and Gladescat.
"It is what it is."
