Frog Spit
Cowboy Rock
Frog Spit
Post by Cowboy Rock »
Need a number or PM info, of someone who sells Frog Spit,,,
Thanks,,,
Cowboy
Wet Dreams Too,,,
14 ft. Panther,,, 370ci SBC, 72 in Whirlwind Whispertip, Line-X-350 X bottom,,,
"Full bloodied Dog hunting man"
Dry Branch, Ga.
Thats how I roll,,,
Re: Frog Spit
Post by kwanjangnihm »
Ron Porter 863-581-6896
frogspit55@yahoo.com
:rebel:
Cowboy Rock
Re: Frog Spit
Thanks friend
Wet Dreams Too,,,
Dry Branch, Ga.
Thats how I roll,,,
mrhuffy
Re: Frog Spit
Post by mrhuffy »
Can you put frog spit over the line x bottom? My son has line x on his boat and would like to make it slide a little easier.
Mike Hoffman
KRVSA Member
GeeLeDouche
Re: Frog Spit
Post by GeeLeDouche »
mrhuffy wrote:Can you put frog spit over the line x bottom? My son has line x on his boat and would like to make it slide a little easier.
I doubt it. you'd probably have to grind all that line x off. or at a very minimum scuff it up REALLY good then clean it up. but the safe bet is to just grind it all off and start fresh.
billybob
Re: Frog Spit
Post by billybob »
Call Brian at Quick Slick. 863-681-9710. He ships and can help you out.
I do all my own stunts!!!!!!
