Propeller Theft Deterrent
Duece
Post by Duece »
Is there any sort of keyed bolts you can use on the hub to prevent someone from say, stealing the blades, or for that matter the entire propeller?
Duece
"Welcome to the Dark Side..."
Dirtman
Re: Propeller Theft Deterrent
Post by Dirtman »
If you do a search for prop lock on SA you will probably find a thread from a couple years back. Southernrican had a set up that locked the two halves of the hub together
terrible ted
Post by terrible ted »
Find an uncommon style drive bolt. A reverse torx an anti theft or safety torx
AceNtheHole
Post by AceNtheHole »
Maybe a motion sensor that swings the prop when someone puts their hand in there. That should deter them.
terrible ted
Dehead them that way. works for me.
loudmouse
Post by loudmouse »
A remote start triggered by a motion detector. That should catch them dead in their tracks. :toothy7:
Built and Tuned by Me
mojoe
Post by mojoe »
It wouldn't be hard to make a hinged steel box to lock over the hub making it impossible to access the bolts without cutting it off. Would slow them down. But you would be out a prop any way if you ever forgot it on there and fired it up.
Mark 7:9
MYDIXIEWRECKED
Post by MYDIXIEWRECKED »
My buddy Bruce Ward had one on his boat here in the glades. He had it made I believe. if you want I'll see if I can get you a pic and what it cost or who makes them.
THOUGHT FOR THE DAY
Lifetime member NRA
In the Glades
Post by In the Glades »
That is a Bruce Ward design lol.... he had a guy locally make it for him I believe
BCAHCC Member
CactusJack
Post by CactusJack »
Maybe one of these?
It is a very good deterrant :shock: :lol:
