bill roberts gear box
odcjohn
Post by odcjohn »
need help making my own gearbox setup with a lycoming box need photos of the way the gear box adapts to the flexplate
Re: bill roberts gear box
Not sure if this will help but it is something to look at!
The drive has it's own shaft that is a smaller yoke. A plate in this case a soft drive is bolted to the drives yoke. Then the flex plate will bolt up to the soft drive and connect the engine to the drive. The soft drive plate can be purchased from Panther for about $100 and may serve as a usable component to fabricate your own connection.
Rotator Pics soft drive.zip
(75.32 KiB) Downloaded 165 times
terrible ted
Post by terrible ted »
Do you have the round gear that sits in the end of the box?
This gear will bolt up holding the flywheel onto the crank (modify and make adapter). Then the box sits on- in it. You have to make a bell housing that thickness to match upto the box flange. Also there is a seal that will be in the housing. It fits over that gear sealing in the gear box oil (keep this in mind as you make adapter or modify the gear). Seal the box to the bell housing - silicone will work.
The vent on the box must be used do not plug it off. If you do the box will build pressure and blow all the seals or the plug out. Use aircraft oil.
pontoon outlaw
Post by pontoon outlaw »
here is how Bill set mine up with the Cad 507
pontoon outlaw
from the side sorry it's not a closer look :)
terrible ted
yea the bell housing on pontoons boat look like one I had 10 to 20 years ago. aprox 2-3 inches thick made out of 1/2 alum.
If that Pontoon Drive could talk.....lol
odcjohn
Post by odcjohn »
Could you take some pic on how it attaches to engine / fly wheel and yes i do have the baslet that boltet to the lycoming crankshaft
pontoon outlaw
:scratch: it's a custom one of a kind adapter plate that Bill created from a thick piece of aluminum, I guess some things just need not be explained :thumbleft:
terrible ted
my old fly wheel sat were it would normally with a small steel round plate over it with counter bored holes for the mounting bolts. There was also a threaded pattern in it for the gear that the box slides over. the Bell housing was made out of aluminum the edges were 3/4 thick, the flat back was 1/2 inch.
Not that complicated. Just need the measurement for the bolt patterns for the fly and the gear for the gear box.
I forgot the end of the gear box sits snug inside a hole in the adapter. on an aircraft it sit inside the crank that would be in the adapter the sandwiches the flywheel to the crank.
THE NIGHT RIDER
Post by THE NIGHT RIDER »
Hey turtle , go ahead unbolt your prop then drain ur gearbox and unbolt it from the back of ur engine ,but make sure u jack your engine up forgot that , then take the pics for the guy would ya
!!! IM THE REAL NIGHT RIDER B!TCH !!! !!! AND A PROUD TO BE IN THE DIAMONDBACK FAMILY !!!!
terrible ted
I don't know am I describing it good?
pontoon outlaw
:stirpot: ha ha sounds :fishing to me
terrible ted
I remember the design. Really not that difficult. It will just take good measuring and a decent Bridgeport & machinist. My bell housing was a welded assembly.
terrible ted
odcjohn
Post by odcjohn »
thats great thanks terrible ted i get it now
terrible ted
Remember the gear has to seal against the adapter to. That box only runs maybe 1 qt oil.
