Need Help 2A Now
- digginfool
- Site Supporter - III
Need Help 2A Now
A plate on my prop is cracked and Im stuck at camp. Can someone get me in touch with Tom Schmidt? I need a prop now.
- digginfool
Re: Need Help 2A Now
- digginfool
Elevator Guy is bringing his Warp out to me.
Tom's out of state on vacation
Treasurer FAA
Svcliche@yahoo.com
Treasurer FAA
Svcliche@yahoo.com
Greg (Diggin) should be back in action now. My Son was able to pick up Jason's (Elevator Guy) warp drive, and deliver it to Greg in 2A. They had it bolted on when my Son decided to head back to the ramp.
- digginfool
Yes he did. I couldn't believe he came down just to bring me that prop. Thank you so much! I'm so fortunate. That plate was moments from total failure.
No problem Greg, glad we could help. Hope to ride with you next weekend!
glad it all worked out
12 ft Don Davis / 0470 conv / 68 NGQ , A.A.O.F member
Best laid plans of mice and men, wont always get you laid.............
Diggin, do you have any idea why the plate failed? Do you think it was just fatigue or some other factor? It might be the camera angle but it looks like the end of the through bolt is very near the flywheel, is there a possibility that the end of the starter bendix contacted it when it engaged the starter ring? Just wondering.
That is a scary fail, glad you found it before it went bad. I don't even want to think about what could have happened Diggin!
- digginfool
I don't even want to guess how it happened. Wait until you see the whole plate. Scary. I felt like puking when I saw how bad it is. I'll post pics later. I noticed a very slight vibration right at the end of my last ride. Going out to camp yesterday, felt the vibration a little more. Started looking everywhere. Checked every blade, made sure all the bolts on the prop were tight, checked alternator bolts; everything good. Finished unpacking and decided to ride over to another camp when the vibration started getting stronger and I knew I definitely had a problem. Eased back to camp and that's when I found the crack.
- Southern Airboat Member
i have a new 5 blade warp drive hub with spacers and all in davie contact me if you need it $200
lycoming o540 11/7 6 blade warp drive
6 idler fulltrack "Midnight Run"
- digginfool
Look how bad this cracked. The streaks are just anti-sieze.
- digginfool
No cracks on face plate.
- digginfool
n
- digginfool
n
Count your blessing that that thing didn't fly apart and hurt someone or something. Must be living right
Wow, that was a close one!! Glad you caught that in time
Palm Beach open hull 13'9" with 6.0 F.I. LS - Ox Box and a 3bld "R"
You got lucky on that one, but damn you are rough on props.
Diggin is there any effort to diagnosis the cause of the defect?
It is a Whirlwind hub assembly right? Are they interested in examining the defective component?
By chance was this one of the prop set up's that runs staggered pitch?
- digginfool
I'm not going to hazard a guess as to why this happened. However, I was not running a staggered pitch, nothing hit the prop and nothing was loose. I've already spoke with the manufacturer and arrangements are being made to get the whole prop and all the hardware to them to analyze what may have happened. We spoke at length about the event and issues leading up to it but I will leave the final analysis to them. Once I receive it, I will share at that time. Not trying to be a hardass but want to be fair to the manufacturer. They are being very cooperative and they deserve their time.SWAMPHUNTER45 wrote:Diggin is there any effort to diagnosis the cause of the defect?
- digginfool
Now that the prop is disassembled and the plate is relaxed, look how close to disaster we were.
- Birddog247
Scary to say the least!
12ft Palm Beach
stock 350sbc
2.1 gear/80"NGR
"Save a tree; eat a beaver"!
stock 350sbc
2.1 gear/80"NGR
Glad to hear they are taking it all back for analysis.
