PE-60 cylinders
FROGGER
PE-60 cylinders
Post by FROGGER »
anybody know where I can get 4 cylinders and 4 high compression pistons for a PE-60 90 hp
FROGGER
Re: PE-60 cylinders
Post by FROGGER »
im probably putting this in the wrong place but does anybody know where I can get 4 cylinders and high compression pistons for a PE-60 90 hp I think they r c-85 pistons if I remember correctly thanks in advance all help appreciated
Re: PE-60 cylinders
Post by Deano »
I would try calling or send a PM to (in no particular order):
Gary Barber @ Outlaw Aircraft Engines or
Speed Wheelie (Tom Jeffords) @ Jeffords Airboats or
Justin Ficken, JT540 on this board.
Their contact information is all over the board, should be an easy search.
If one of them can't help you, I would be willing to bet that they know who can.
FROGGER
Re: PE-60 cylinders
Post by FROGGER »
thank you deano I will call them tomorrow
dblj006
Re: PE-60 cylinders
Post by dblj006 »
Broke.
pgs2845
Re: PE-60 cylinders
Post by pgs2845 »
I'm pretty sure I have those pistons in .015 and STD.
FROGGER
Re: PE-60 cylinders
Post by FROGGER »
how much and where
pgs2845
Re: PE-60 cylinders
Post by pgs2845 »
$50.00 each for pistons. Haines City
pgs2845
Re: PE-60 cylinders
Post by pgs2845 »
Ducarra Aviation HAD new cylinders
