Trim tabs
Best airboat discussion on the internet.
BWXSTREAM
Trim tabs
Postby BWXSTREAM » Thu Apr 06, 2017 12:29 pm
Do any of you guys know how I can get my boat on plane easier under heavy load would bending the tab down in the back help when I throttle up under heavy load my boat just plows water until it gets skinny
Re: Trim tabs
Postby Deano » Thu Apr 06, 2017 12:47 pm
You will have to tell us non-psychic folks more about your boat and it's power before we can help.
Far to many variables to cover all the basis.
pontoon outlaw
Re: Trim tabs
Postby pontoon outlaw » Thu Apr 06, 2017 1:10 pm
Must be an aluminum hole just like mine
Sent from my E6833 using Southern Airboat mobile app powered by Tapatalk
BWXSTREAM
Re: Trim tabs
Postby BWXSTREAM » Mon May 01, 2017 8:05 pm
it is a 5000 lb 20 foot boat with a centry drive 2;1 whirlwind super wide on a 572 bbc prop may be pitched to much? can only get 4000rpm out of her
Re: Trim tabs
Postby SWAMPHUNTER45 » Mon May 01, 2017 8:48 pm
Well you are not into the horsepower range of that engine if it is a GM Performance 572 that has not been altered.
The 572/620 drops it's torque curve at 4200rpm and is still building horse power up to 5400rpm.
How many blades are on the prop and what is it's diameter ?
A different gear ratio may be the best remedy and be you must be alert to your blades rpm limitation.
You can try the tab but at speed it may go on it's nose which creates other problems. Sounds like your lacking thrust.
Prototype
Re: Trim tabs
Postby Prototype » Mon May 01, 2017 10:36 pm
BWXSTREAM wrote:Do any of you guys know how I can get my boat on plane easier under heavy load would bending the tab down in the back help when I throttle up under heavy load my boat just plows water until it gets skinny
BW,
First off this is not an Immediate responder site if there is one? Get real with tuning a boat or break the wallet out to buy one! No shame in that, lots do!
No need to post all over the place for your issues! Some of us have other things to do! Like tuning our own rigs!
Put it clear, your rig weights out a 5 thousand, plus another one in fish caught per trip. Honestly your catching a thousand pounds of fish per trip and your asking advice?
That's like asking floridians what they do to plane there boat after a successful moose hunt? Your post"s" is leading to a fish charter business, not help with a airboat!
One guy pulls a thousand pounds of fish a day or worse per trip daily???
Re: Trim tabs
Postby Deano » Tue May 02, 2017 9:06 am
Prototype, my reaction was similar. :roll:
Should've bought aluminum. :dontknow:
My boss had a steel hull years ago that would tote that load . . . but it was 42' w/ a pair of 496s. :D
On a less humorous note, adding a 4th blade, switching pulley's to
a 2.3 and turning the engine 5400 would be a good, reasonable start.
A couple relevant notes -
1 - Trim tabs can and will bring the bow down, they will not lift it up, and
2 - Correcting prop pitch is no substitute for proper weight distribution. (move dead fish aft)
Re: Trim tabs
Postby kwanjangnihm » Tue May 02, 2017 9:42 pm
Re: Trim tabs
Postby SWAMPHUNTER45 » Wed May 03, 2017 12:04 am
I struggle to grasp why that ratio was selected?
It is just plain wrong in my opinion for that power plant and prop.
That fat boat screams 2.52 or 2.67 and 4 blades to me!
Users browsing this forum: Google [Bot] and 5 guests
