Battery ground
Best airboat discussion on the internet.
diamondback0320
Battery ground
Postby diamondback0320 » Sat May 06, 2017 12:07 pm
Is it really necessary to ground from battery to the engine..Reason for asking is that's where I'm grounded now..Getting new cables made & not really a lot of places to bolt a ground on the aircraft motor..Besides that every mount is a rubber mount..So seems to me a more solid place to ground would be somewhere more solid like the rigging or the aluminum stringers as I have a aluminum hull..Idk just a thought
ladyblackwater
Re: Battery ground
Postby ladyblackwater » Sat May 06, 2017 12:38 pm
Your best bet is to run a ground from the battery to the starter housing. If you don't have a good ground to the motor it will leave you stranded at some point very soon. This is a common problem I see all the time.
Greater love hath no man, than to lay his life down for a friend.
Bitterly clinging to my guns and my religion!
I am that conservative republican your momma warned you about!
rac1boat
Re: Battery ground
Postby rac1boat » Sat May 06, 2017 12:55 pm
Ground motor to rigging, from rigging to hull with double 00 cable you won't have any problems
Re: Battery ground
Postby Deano » Sat May 06, 2017 1:46 pm
ladyblackwater wrote:Your best bet is to run a ground from the battery to the starter housing . . .
X 2
Given level of importance, this is the best place to start. Doing so may save undo strain on the starter and grounds the block all in one motion. Running a jumper from there to the rigging/engine stand will get that as well.
On a boat, you can not have to many grounds. Redundancy can and will save immeasurable grief over time.
My current setup has two from the battery ground: the first goes to the starter/block, the second to the rigging near the battery. There is additionally one from the starter/block to the engine stand. This one is by rights redundant, and ought not be needed, but serves as a back up and cheap insurance. I've had no electrical hiccups in eight years now, so have become partial to this arrangement.
pontoon outlaw
Re: Battery ground
Postby pontoon outlaw » Sat May 06, 2017 2:29 pm
Mine is grounded to the engine had to sand the area where connection is
Sent from my E6833 using Southern Airboat mobile app powered by Tapatalk
diamondback0320
Re: Battery ground
Postby diamondback0320 » Sat May 06, 2017 6:22 pm
Thanks for the replies..Hmm starter bracket probably gonna b the best bet!
terrible ted
Re: Battery ground
Postby terrible ted » Sun May 07, 2017 10:11 am
I run 2 grounds one to motor one to rigging.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 21 guests
