1/4 rod keeps breaking.
Krahammer
Post by Krahammer » Tue Jul 04, 2017 10:17 pm
The center rod that holds my flame arrester and hood onto the top of my Holley Carb keeps snapping off. I have tried all kinds of threaded rod, including hardened rod, to no avail. I don't want that thing to fly into my prop. Any ideas?
SHOOTER250
Re: 1/4 rod keeps breaking.
Post by SHOOTER250 » Wed Jul 05, 2017 5:41 am
Until you figure out how to stop that you better safety wire your spark arrester to the motor
Andy
Post by Andy » Wed Jul 05, 2017 5:59 am
I had the same problem, I ended up drilling and tapping it up to 5/16. It hasn't broke since, I have a Quick fuel don't know if you have enough metal?
Post by SWAMPHUNTER45 » Wed Jul 05, 2017 7:10 am
If it is over sized it may require you to ad some bracing to reduce the force and harmonics it is exposed to.
Krahammer
Post by Krahammer » Wed Jul 05, 2017 4:26 pm
thanks for the responses. Safety wire done the first time the bolt snapped. The 1/4 inch hole is not oversized. I will have to check and see if the Holley has room to drill and tap to 5/16. However, it doesn't seem enough of a difference to keep it from snapping.
mojoe
Post by mojoe » Wed Jul 05, 2017 5:52 pm
Krahammer wrote: The 1/4 inch hole is not oversized.
I don't think he is asking if your hole is oversized, he is talking about the filter/flame arrester. Some people put some pretty big ones on there.
I ran a Holley for years with a 10" filter and a dog bowl to keep the rain out. It was drilled and tapped to 5/16". It was like that when I got it and I never knew why, but i never had a problem so I didn't think about it much. Just put some 5200 on the threads to keep it from vibrating loose. Ran it 4+ years.
Mark 7:9
GMAC 76
Post by GMAC 76 » Wed Jul 05, 2017 9:42 pm
have ya tried a long 1/4" BOLT with a lock washer instead of threaded ROD and a nut??
Post by Deano » Wed Jul 05, 2017 10:19 pm
The Holley does have sufficient room to drill and tap for 5/16".
I had similar issues with mine years ago, and that was the fix for me.
I additionally bottomed out a rod coupling nut against the base, like a jam nut.
This helps to spread any strain over a greater area of the stud.
Haven't ever had that problem again in seven or eight years now.
Krahammer
Post by Krahammer » Wed Jul 05, 2017 10:36 pm
Again, thanks for all of the suggestions. I already use the coupler nut idea, it keeps the rod from breaking off level with the top of carb and having to drill it out. I like the bolt idea, it has to be stronger than threaded rod. Before I drill and tap, I'll try it.
