Need HELP!!
Boogie320
Need HELP!!
Post by Boogie320 »
So in new to the airboat world and I bought 10' boat with a O-290 GPU 125 HP. It started the first 3 different times and now i can't get it to start. I checked the battery, battery cables everything is getting power. Fuel pump is pumping and is getting fuel to the engine but it just won't crank over. If anyone has any suggestions it would be a great help.
Thanks!!
BANANA BOAT
Re: Need HELP!!
Post by BANANA BOAT »
Spark, compression and fuel
Sent from my SAMSUNG-SM-T377A using Southern Airboat mobile app powered by Tapatalk
jeepinocala1111
Re: Need HELP!!
Post by jeepinocala1111 »
Is the starter turning it over? If so I would say make sure the mag is not grounded. There is a small wire coming out of the mag or mags if it is grounded that is how you turn them off.
Swamp Thang
Re: Need HELP!!
Post by Swamp Thang »
jeepinocala1111 wrote:Is the starter turning it over? If so I would say make sure the mag is not grounded. There is a small wire coming out of the mag or mags if it is grounded that is how you turn them off.
Whatever you do just make sure you don't put power to the mags because you'll burn them up, when they are Off they are grounded and Not grounded is On
if you determine it is a spark/mag issue call Gmac76 on SA...Greg is a good guy who will fix it right for a reasonable price 863-659-1331
GMAC 76
Re: Need HELP!!
Post by GMAC 76 »
you said it wont crank over so I assume your saying the starter will not turn the engine over so it will start....so starter, starter switch or wiring to starter
Re: Need HELP!!
Post by kwanjangnihm »
Mine would not start about a month ago. Charger showed a full charge but when I hit the button NADA!
Had the battery checked and it had a dead cell (only 9volts). Was under warranty. New battery worked like a charm!! :thumbleft:
Boogie320
Re: Need HELP!!
Post by Boogie320 »
Whatever you do just make sure you don't put power to the mags because you'll burn them up, when they are ON they are grounded and Not grounded is OFF
Yes starter turns over. So when starting megs have to be grounded correct?
Boogie320
Re: Need HELP!!
Post by Boogie320 »
kwanjangnihm wrote:Mine would not start about a month ago. Charger showed a full charge but when I hit the button NADA!
Ya I tested the battery and I'm getting 13v all the way around.
GMAC 76
Re: Need HELP!!
Post by GMAC 76 »
NO......if mags ARE GROUNDED they will NOT FIRE....grounding the mags is what shuts them off
diamondback0320
Re: Need HELP!!
Post by diamondback0320 »
You got to it B4 I could Greg..GOOD CATCH!!
GMAC 76
Re: Need HELP!!
Post by GMAC 76 »
diamondback0320 wrote:You got to it B4 I could Greg..GOOD CATCH!!
great minds............uh tony...lol
Boogie320
Re: Need HELP!!
Post by Boogie320 »
Thank You I appreciate it
ill let you know how it goes. when i get out of work lol.
Swamp Thang
Re: Need HELP!!
Corrected my post, sorry Boogie it was late and meant to say it the opposite way like Jeepin & Greg said.
