Airboat or Surface drive?
VJ
Post by VJ »
Hello,
New to forum. Any of you guys run Yankeetown to Wacassassa? I will be retiring soon from Fire dept and would like to purchase a Surface Drive or Airboat. Would like to see if anyone would allow me to ride along on an Airboat on some of the creeks in the Yankeetown area. Not looking for anyones fishing spots, but would like to see which boat would be the most applicable. I would be willing to pay for fuel and eats. Thanks.
VJ
2005 Diamondback, 388 chevy, 2-1 CH3
barhopper
Re: Airboat or Surface drive?
Post by barhopper »
Airboat
Post by Deano »
While you may expect biased opinions on an airboat board, unanimous agreement against a surface drive could be easily justified with no bias involved. Likely the only person to tell you different, would be the Surface Drive Salesman. :lol: (And then, only IF he'd never owned and/or operated an airboat).
The fact that you would pose such a question makes it sound as though you've never run a surface drive. Even when you have deep, clean water, operating a surface drive is like work compared to an airboat. Throw in shallow and/or weed laden and the work load increases, sometimes exponentially. While it may sound counter-intuitive if you've never operated either, an airboat is additionally far more maneuverable.
I kind of take retirement to imply at least some kind of quality of life.
Compared to an airboat, a surface drive simply doesn't excel at promoting that.
VJ
Post by VJ »
Thanks for the advice guys. You would be correct, as I have never owned either. Guess I will start looking for an Airboat.
Thx
papajack
Post by papajack »
PM sent.
Duece
Post by Duece »
Airboat. Chicks don't take their clothes off for surface drives...
Duece
"Welcome to the Dark Side..."
Waggs
Post by Waggs »
Surface Drive, quieter and more fuel efficient. Already too many airboats out there.
Liberty Mechanical Services
321-689-7709
Making America Cool Again!
KCCO
ringneck
Post by ringneck »
Had surface drive longtail, short tail, and a18 ft. V8 true mudboat. Only reason I ran those rigs instead of Airboats
was that some Wildlife Management Areas we hunted did not allow any Airboats. Given a choice AB was always my pick.
When I retired in 08 I quit working my assofft wrestling with Surface Drives. RETIREMENT IS SUPPOSED TO BE FUN.
Ride a good AB one time where you plan on spending your free time. You won't be disappointed.
16x8 AIRRANGER RHINO, LEVATATOR 450, CH3, WHIRLWIND 3B-80
Aircraft hand prop tractor, half guard old school survivor
VJ
Post by VJ »
Thx Ringneck, think I will pursue the airboat. Appreciate the advice.
barhopper
Post by barhopper »
An airboat will go everywhere a surface drive goes but a surface drive won't go everywhere an airboat will. A perfect world would be having both. I start fishing about every week starting in September. Give me a holler, I'll haul you around a time or two.
VJ
Post by VJ »
Thanks Barhopper, I really appreciate that. I will contact you in Sept or Oct. Would really like to see what I'm up against in those creeks.
Vj
barhopper
Post by barhopper »
No problem. I usually go at least once a week.
Post by One Eyed Gator »
I fish that area as well and anything with a prop is no fun, lots of big nasty sharp rock. I see guys poling, trolling motoring or dragging boats as I just wave a slide by. South to yankeetown is not so bad but north to cedar key is nasty and very rough on a boat. If you ran a surface-drive you would still need poly in my opinion or you would end up with a hole in the boat. The water was murky and I hit a big sharp rock at the end of last year, shaved a football size piece of my poly off and poked a quarter size hole through my hull. BTW we hammered the reds that day Caught at least 15 over slot reds or 50 slot reds and of course only kept the FWC generous limit of 1 red (what a joke). Once you ride in an airboat an fish that area you will get a better understanding
As barhopper said sept is the start.
VJ
Post by VJ »
Thanks for information and advice Gator.
mixedbag
Post by mixedbag »
PM'd you.
RAGE IN A CAGE
nomad41
Post by nomad41 »
Airboat is the way to go. You will want one with poly on bottom. Oh just so you know there are only 2 kinds of airboaters. The ones that have sunk one and those that just haven't yet lol
Treasurer FAA
Svcliche@yahoo.com
akblackdawg
Post by akblackdawg »
if you need to run dry or areas too shallow for a prop, less then 6-8 inches depth, get a airboat, and they are more fun. if you can limit to where there is minimum 6-8 inches of water, a surface drive will be a lot less expensive, better boat to actually hunt out of, and quieter, thus a better hunting boat. but not near the pucker factor or the fun
GeeLeDouche
Post by GeeLeDouche »
get both..
I have both and they both have their benefits. the hyperdrive Mudbuddy does awesome on gas and if its only 2 or 3 of us going, I'll take the mud boat every time! If I want to chase mallards in puddles of water only a couple inches deep and have 4 of us going,, i'll spend the $ on gas and go blast some ducks. I can use the duck boat year round as a fishing boat and the airboat is only viable during duck season here. the fun factor driving the airboat is over the top. but the efficiency of the mud boat sure makes it appealing a lot of times, especially in early season duck hunting. It just doesn't make sense to compete with the crowds to shoot a handful of young early season ducks and spend 50 bucks on airboat gas on top of that. but when the mallards and pintails come in and they are all sitting on puddles that mudboats cant get to, or on the ice the airboat has the upper hand. so its a trade off.
FrikkiDikki
Post by FrikkiDikki »
I too, have both . A Mudbuddy Hyperdrive on a 15/52 aluminum tunnel hull, and an O-360 on a 12' Cottonmouth. 75% of the time, you'll find me out in the surface drive. It's quiet, even with the BPS pipe, and much more economical. However, for gigging and getting into places where you might have to drive over stuff or run dry, nothing but an Airboat will get the job done. Both can be big fun if you're just out joy riding, but the surface drive is more of a slow motion kinda fun. Either way, it'll require some practice to be a safe and competent operator.
