Fiberglass
hoghungry
Fiberglass
Postby hoghungry » Sat Sep 23, 2017 9:34 pm
Could something like this be glasses over on the bottom or is it a wast of time?
Sent from my SM-J327V using Southern Airboat mobile app powered by Tapatalk
hoghungry
Re: Fiberglass
Postby hoghungry » Sat Sep 23, 2017 9:36 pm
This is a spot on a different hull
skinnypockets
Re: Fiberglass
Postby skinnypockets » Sun Sep 24, 2017 9:43 am
If it's glass it can be repaired. The question is; is the hull worth what it will cost for the repair?
:rebel: :florida: :old_glory:
leo_081103
Re: Fiberglass
Postby leo_081103 » Thu Sep 28, 2017 4:32 pm
hoghungry wrote:Image
although this is a repair patch, it amazes me that some fiberglass boat builders don't take the effort to stretch and align the fiberglass properly. this is one big factor that makes fiberglass boats either give a solid ride or a flexible feel :scratch:
if you DIY your fiberglass boat or do a repair, make sure the fibers are stretched and aligned :!:
14 ft x 7.5 ft FG 5/16" UHMW-PE
150hp 1.6L (98cu.in.) Toyota 4AGE-20V
78" 3 Blade ground adjustable Wood prop (Home built)
78" 3 Blade Sensenich R Series
3.75:1 Belt Drive (Home built)
hoghungry
Re: Fiberglass
Postby hoghungry » Thu Sep 28, 2017 4:51 pm
Yeah I will man I need to learn about fiberglass. But this repair was already done before I bought it
Users browsing this forum: No registered users and 52 guests
