Boat registration
Basin_Runner355
Boat registration
Post by Basin_Runner355 »
I bought my boat last year and the GW are cracking down on boat's and having the correct paper work on my registeration under propulsion it says outboard when I bought it the ppl that did the paper work sent it off and took care of it. I've heard that it should say inboard and I've heard ppl say it should be other just wondering what y'all take on this was and how to get it straightened up I'm in Louisiana
14ft diamond back mild zz4 355sbc pushin 450 hp 450 TQ 2:1 belt drive reduction with a 3 blade sensenich 78Jw series
Re: Boat registration
Typically you would go to your tax collectors office in Florida and point out that an error was made when the title was applied for. Usually when they are digging that deep it has another purpose such as someone took a title "paper boat" and transferred the hull id number and registration to another boat. Did you build the boat or was it purchased with that discrepancy? Does it list a manufacturer?
Basin_Runner355
Yea it's a diamond back the hull id number matches the paper work but it's kinda sketchy cause two of the numbers are wrong but on the side of the two wrong numbers the right numbers are stincled idk what took place before I got the boat cause the boat is almost 20 years old but I bought it with a bill of sale and all of that and have the title just trying to cover my ass incase I get stoped
Basin_Runner355
What should it say for propulsion
Post by Deano »
What paperwork has the hand made correction on it? Which paperwork matches the Hull Identification Number?
Is the Title correct, with the Registration containing the 'fix' ? Or
Is the Registration correct, with the Title containing the 'fix' ?
I bought a motorcycle one time that had two numbers transposed in the VIN on the title.
The Registration matched the wrong numbers on the title, so the registration looked to be for a different bike.
The current owner I bought it from never even knew the numbers didn't match. Ultimately, I rode the bike to the tag office and showed them that a seemingly dyslexic clerk had originally processed the paperwork and they fixed it when I transferred the title.
Problem solved.
Much easier to explain with paperwork in hand and boat in the parking lot (at your convenience) to an office clerk, than to
the Game Warden after you've been on the water all day, and he has an aggravated, unrelated, pre-existing case of the berries.
Riding with corrected paperwork may be legal, but also seems to attract undo, unnecessary and easily preventable grief. :wink:
As far as propulsion, in Florida the designation is 'Other'. As long as there is another option, I would insist that it not be listed as 'Inboard' because that could open a whole other can of worms where gas tanks, venting, blowers, flame arrestors and all that other potentially irrelevant crap is concerned.
Basin_Runner355
Yes the paperwork matches the numbers that are fixed on the boat Ima have to check the title when I get home so it should say other guess Ima have to get that all straight just don't wanna draw attention to my self getting it fixed but I want it to be right
Waggs
Post by Waggs »
My registration shows for propulsion "airprp" .... just syayin
Liberty Mechanical Services
321-689-7709
Making America Cool Again!
KCCO
diamondback0320
Post by diamondback0320 »
X2
Post by Deano »
Oops ! :oops: My bad . . . you guys are exactly correct. :thumbleft:
In spite of reading and then writing 'propulsion' I was still thinking engine type. Mine all read the same as yours do.
I guess after I read inboard earlier, some renegade brain cells took possession of my fingers, and went on their own tangent. :lol:
What I put above would be applicable to engine type for the above reasons. Unfortunately, that wasn't the question. :roll:
BANANA BOAT
Post by BANANA BOAT »
Shoud be airprop
Sent from my SAMSUNG-SM-T377A using Southern Airboat mobile app powered by Tapatalk
Rick McC.
Post by Rick McC. »
Waggs wrote:My registration shows for propulsion "airprp" .... just syayin
Mine too.
Rick
http://guntipsandtalk.com
