Ice boat stuck
Putz
Ice boat stuck
Postby Putz » Thu Dec 28, 2017 1:47 pm
Took my ice boat out on the snow for the first time yesterday, made I few laps around the house then went out on my pond. Broke thru the ice ( poor ice lots of snow on it) made a loop a round everything's going good. Climbed back up on the bank and instantly froze to the ground. Stuck to the point that I couldn't even budge it with a strap and my pickup. Had to jack it up and scrape the snow and ice off the bottom before I move it. What gives? I've always heard snow and ice were no problem. Boat has 3/8 super slide poly on it. It was 13 degrees 6-8 inches of fluffy snow.
bkmail
Re: Ice boat stuck
Postby bkmail » Thu Dec 28, 2017 2:16 pm
Yep, wet bottom froze down to ground. When we park after riding in snow we park the boat on logs, branches, carry a couple 2x4's to toss out and stop on. Or else your froze as you found out.
Bk
Putz
Re: Ice boat stuck
Postby Putz » Thu Dec 28, 2017 5:37 pm
If there is an wide crack in the ice will i be able to cross and keep going? This happens here on lake Erie almost every year. people on foot or quads need to be rescued by the coast guard.
swamper2
Re: Ice boat stuck
Postby swamper2 » Thu Dec 28, 2017 8:00 pm
what equip are you running. Power , hull?
Putz
Re: Ice boat stuck
Postby Putz » Thu Dec 28, 2017 8:38 pm
Home built hull, 3/16 aluminum with 3/8 poly, caddy 500, 1.77 belt reduction with a 78 inch two blade ww whisper tip 2.0
bkmail
Re: Ice boat stuck
Postby bkmail » Thu Dec 28, 2017 10:05 pm
We splash in/out of water on step, over ice, in the snow, etc.....but dont park a wet hull on the ground/snow. The ice and snow builds and sticks to the hull when stationary.
The same happens running snow, friction warms the bottom and you need to park the boat on something so it doesnt freeze down.
Throw down something like lumber, then park on top.
Bk
Putz
Re: Ice boat stuck
Postby Putz » Fri Dec 29, 2017 7:06 am
Ok thanks for info bk. I wasn't trying to stop, had my foot to the floor it stopped me. I will do some more experimenting before I head out on the lake.
dave1971
Re: Ice boat stuck
Postby dave1971 » Mon Jan 01, 2018 12:55 pm
God I'm so glad I dont have that problem in Florida!!!
bkmail
Re: Ice boat stuck
Postby bkmail » Tue Jan 02, 2018 3:49 am
search.php?author_id=16354&sr=posts
Putz,
Heres some video running in/out of water on snow/ice.
Klondike Jim's video about 4 mins in is a good example.
Bk
Putz
Re: Ice boat stuck
Postby Putz » Tue Jan 02, 2018 4:13 pm
Cool vid, thanks again bk. I'll be in ak again this summer, mostly by anchor point. If i get up near Palmer I'll look up
Putz
bigkavr
Re: Ice boat stuck
Postby bigkavr » Wed Jan 03, 2018 10:33 am
Putz,
Great advice from our northern airboaters!!
What you're describing is something that happens more so during freeze up than other time. But it can happen any time in the winter...
One thing to remember is that your hull is going to be the same temp as the air. When you break through the ice and then climb back onto snow, the snow instantly freezes to the bottom of the hull. And contrary to popular belief, ice can stick to poly just as easy as it will stick to anything else.. It may continue to build up till you're stuck, depending on the temp and snow conditions. (this is a 2 hour discussion in itself...)
Best thing to do if you break through is to get back on bare ice if possible. If this isn't possible, then try to go as fast as possible (SAFELY) for a few hundred yards to wear the buildup of snow/ice off the bottom before you park. And as noted in the above posts, ALWAYS park on a 2x4, branches or something to prevent the entire hull from staying in contact with the ice. You don't have to suspend the entire hull off the ice, just having the front half of the hull off the ice is enough.
If you do freeze you hull to the ice, do not try to pull the airboat straight ahead to break it loose. this can put tremendous strain on your hull.
The easiest way is to pull your bow 90 degrees from the direction of travel. This "twist" action only needs to move your bow about 1" to 2" sideways to free your hull. Up in Northern Canada when I was teaching airboat operations, we would park on 4x4s but every once in a while someone would forget and get stuck.. It's amazing how with only an ice screw and one person, you could get your airboat unstuck off the ice. PM me and I can describe how.
Have fun and be safe.
bkmail
Re: Ice boat stuck
Postby bkmail » Wed Jan 03, 2018 1:11 pm
Anytime Putz! Give a shout if your up this way.
Bkmarineservices.com
Brian
Wcrenz
Re: Ice boat stuck
Postby Wcrenz » Thu Jan 04, 2018 9:40 pm
I am thankful I found this. Been preparing to go boating now we have this cold snap here on buckeye lake. Not knowing this would been a hard lesson. Saturday should be first day out. So far I only been pulling off and lubricating cables and fixing trailer parts. Luckily my hitch coupler broke in driveway and not driving down road.
Putz
Re: Ice boat stuck
Postby Putz » Thu Jan 04, 2018 10:33 pm
Wcrenz
Pm sent
Putz
bkmail
Re: Ice boat stuck
Postby bkmail » Fri Jan 05, 2018 3:47 am
Carry some heat to thaw anything, just in case.
Bk
Re: Ice boat stuck
Postby kwanjangnihm » Fri Jan 05, 2018 4:04 am
we have bigger issue with the cold here in Florida! :lol:
Iguanas are falling out of trees in Florida because it's so cold.
https://www.washingtonpost.com/news/ani ... 13c2351377
bkmail
Re: Ice boat stuck
Postby bkmail » Fri Jan 05, 2018 4:53 pm
I near they taste like chicken!
Bk
fjdrill
Re: Ice boat stuck
Postby fjdrill » Fri Jan 05, 2018 5:05 pm
If that fell out of a tree at my house, it would come down with a terminal case of shovel :violent1:
snow bullet
Re: Ice boat stuck
Postby snow bullet » Tue Jan 23, 2018 7:44 pm
i use a 6 foot long piece of 6” plastic culvert to park on at night or any time i stop , it works realy nice never sticks to the hull and is a great way to get moving
Lwells
Re: Ice boat stuck
Postby Lwells » Sat Jan 27, 2018 9:57 pm
I'm curious as to why you guys don't run sprayers with some type of antifreeze ingredient in the sprayer. I'm guessing you could pass over the area where your going to stop and heavy spray it and then turn around and park on the sprayed spot. I don't know that would work for overnight or not but I would think it would work for short time parking or am I completely out of my mind.LOL
bkmail
Re: Ice boat stuck
Postby bkmail » Sun Jan 28, 2018 1:01 pm
Just isnt feasible. Sounds good but.......
Bk
Putz
Re: Ice boat stuck
Postby Putz » Mon Feb 19, 2018 4:48 pm
Well I've been out on the bay a few times since I was stuck, thanks to all the advice pointers from you guys all has gone well. Was glad I had an airboat today as the coast guard had to rescue another guy out of the water again this mourning.
Thanks again
bkmail
Re: Ice boat stuck
Postby bkmail » Mon Feb 19, 2018 6:22 pm
If you need dry forced air heat, check out my Planar heater.
We install the 2d model in the cab of the airboat, nice and toasty. Also make a portable unit for ice houses, wall tents to moose hunt, etc...
Bkmarineservices.com or the Facebook page for lots more photos.
Bk
Air canada
Re: Ice boat stuck
Postby Air canada » Wed Mar 21, 2018 9:09 pm
I find in certain conditions that happend but jacking boat up with farm jack and cleaning bottom off best ya can and a bunch of lengths of PVC pipeing laid under it and ahead of it get momentum from sliding over the pipes and she should get rest of bottom cleaned off with speed or if you can get it turned around back in water keep doing circles in water till it melts the ice amd slush build up off bottom and like others said always park on something skids, 4x4 , 2x4 pvc etc. So she don't freeze down and if you don't have anything to park on do a bunch of circles amd pack snow down to make a parking spot good luck and welcome to ice boating
:canada:
Rich Andrews
Re: Ice boat stuck
Postby Rich Andrews » Thu Mar 22, 2018 9:42 am
Why not build a simple wedge and pull the ft end up on it and get 80% of the hull off the ice?
LOHA is AHOL backwards
Users browsing this forum: No registered users and 41 guests
