Porpoising Problem
Krahammer
Porpoising Problem
Postby Krahammer » Wed Jan 10, 2018 1:30 pm
My boat is a 2009 GTO, 14 foot, open welded aluminum hull. 3/8 Polymer on Bottom, 1/4 inch poly on sides, up 6". 450 HP MAS 383 Stroker, with Sensenich 3 Blade Super Wide H Prop. WOT is 5200 RPM. Has never porpoised before, in any conditions. Sunday, took a ride in Everglades Conservation Area 3A North, which meant a good bit of semi-dry running. I ran for a few hours, off and on, running a total of about 40 miles, running from camp to camp. No porpoise problems until after I left the last camp and started heading back to the ramp, about 7 miles away. Although the engine was developing full power, the boat felt sluggish, like it was dragging something. At 4000 RPM, the boat began to porpoise in only an inch or two of water. I could only get it to stop by reducing back to 3200 RPM. Back at the ramp, put the boat on the trailer and looked at the bottom. There are no tears in the polymer. No loose screws. Can't find any loose polymer. No missing pieces of polymer. The engine mounts and bolts are solid, are all of the rigging and connectors. Does anyone have any ideas of what I should be looking for as a cause of the sudden porpoise problem? Suggestions appreciated!
SHOOTER250
Re: Porpoising Problem
Postby SHOOTER250 » Wed Jan 10, 2018 2:03 pm
Make sure the lip sticking out past the transom
On the bottem is not bent up from running up
Up in the yards to park. I did the same thing in
the same place just bend it down even or just
a little lower and try it .A very little goes a long way make very small adjustments and test it
Krahammer
Postby Krahammer » Wed Jan 10, 2018 4:38 pm
Thanks, Shooter. I had not checked that.
Gary S
Postby Gary S » Fri Jan 12, 2018 6:10 am
You sure there are no rips under the bunks?
Krahammer
Postby Krahammer » Fri Jan 12, 2018 6:17 pm
I have thought of that. Going to lift it off the bunks and make sure before I do anything else. Thanks!
Krahammer
Postby Krahammer » Sun Jan 21, 2018 10:57 pm
Found the problem. When I left the last ramp, jumped a small hill. Apparently landed on a lump of marl or a rock. Caused a saucer size indentation between two stringers just in front of the transom. The indentation was less than 3/16". Removed the transom bracket so we had room to swing a three pound hammer. Used a block of wood against hull and hit it about 5 times. Made it flat again. Problem solved.
loudmouse
Postby loudmouse » Mon Jan 22, 2018 6:45 am
That was going to be my suggestion to look for, a dent near the transom. Glad you got it back running right.
Built and Tuned by Me
Krahammer
Postby Krahammer » Mon Jan 22, 2018 3:43 pm
Thanks for the suggestions!
Users browsing this forum: No registered users and 16 guests
