io520 exaust problem
snow bullet
Postby snow bullet » Mon Jan 29, 2018 6:18 pm
i have benn having a problem my exaust keeps becoming loose i have had the a bunch of the nuts fall right off ! dose any know why this would happen ? i am using the aircraft nuts on the cylinders studs , is there any lock tight or special washers ??
Whitebear
Re: io520 exaust problem
Postby Whitebear » Tue Jan 30, 2018 12:18 pm
If by aircraft nuts you mean nylon-locking nuts, try deformed nuts instead.
snow bullet
Postby snow bullet » Tue Jan 30, 2018 2:11 pm
ya they have a notch in the threads
but they are the same shape as Nylock nuts
i was thiking of using a cole Chisel and just deforming the end of the nut a little bit
Users browsing this forum: John Fenner and 55 guests
