Painting over powder coating
diamondback0320
Post by diamondback0320 »
Anyone know if this can be done..if so what's the prep.. have a fuel tank out of the boat to clean out & freshen it up but it's going to be about $100-150 just to blast it
Sniper
Re: Painting over powder coating
Post by Sniper »
All you need to do is just sand it or scuff it up so the powder coat and it would not hurt to use a good primer that will help adhesion then put a good quality top coat paint on it, I have been painting most of my life and painting over powder coat is no big deal as long as you prep it right
diamondback0320
I kinda figured a good scuff & wipe down with acetone & good primer was the route to take as I was a painter 20+ years just hadn't ever dealt with this situation thanks
mojoe
Post by mojoe »
Powder coat is one of the hardest coatings to adhere to. You can abrade it and get a bonding primer as a tie coat to create a mechanical bond. It will work.... kinda. When you bang it, it will still pop at the primer 90% of the time.
Stripping it is the best way.
Also, if the powder coat is chipped, you will have to sand All the way down there or you will see a ridge due to the high millage that powder typically goes on... not that much more effort or money to strip it and start with bare metal.
Both work. One way just works better. More of a personal decision than a right or wrong kind of thing.
Mark 7:9
diamondback0320
Yeah I stripped some powder valve covers and pushrod tubes and intake tubes couple years back & it was a bear to get that shit off..kleen strip is what I used but haven't tried the aircraft stripper..
diamondback0320
10-4
diamondback0320
Aerosol can? That's what I see online
diamondback0320
Ok I'll give it a try thanks
skinnypockets
Post by skinnypockets »
ladyblackwater wrote:Diamondback0320 Yes it only comes in an Aerosol can. I tried to post a picture but for some reason for the last 2 days it won't let me post any pictures.
Is this the one you're talking about?
https://www.ebay.com/itm/1-Gallon-Klean ... SwEK9T5Lxy
:rebel: :florida: :old_glory:
diamondback0320
No it's in a aerosol can.. trying to upload the pictures but keeps saying unable do to low memory..like I'm trying to download not upload..idk
skinnypockets
diamondback0320 wrote:No it's in a aerosol can.. trying to upload the pictures but keeps saying unable do to low memory..like I'm trying to download not upload..idk
Is this it? https://www.ebay.com/sch/i.html?_from=R ... KLE-EFS459&
diamondback0320
I'll see if I can find it here in town..been busy redoing a buddies trailer..be done tomorrow..then I'll get to my stuff.. thanks again guys!
I have purchased it before from Advance Auto Parts in the paint and body section. Seen spray cans and quarts.
It helps to have scrapers and requires a little bit of timing FYI. You apply it and it starts to soften and lift a finish. As it dries it sort of retacks so you need to hit it just at the right time to get a clean scrape. Then clean the scraper blade and hit your next run. That's my experience anyway on a painted surface.
diamondback0320
Well I tried it yesterday afternoon..sanded with 80grit then rinsed it off & dried it..then sprayed the tank & let it sit bout 10-15min & went to scraping & let's just say it didn't do as desired..I used a whole can on the fuel tank..now I've really got a mess.. maybe do to temps being too cool as it was 67 when I sprayed it.. guess I'll just put the tank in the sun for a while and try again & hope for the best
diamondback0320
Yeah I talked to Tonia yesterday afternoon and she said probably cooler weather..I ended up using regular stripper I already had..4hrs later & I'm almost done lol..was planning on doing dry boxes etc while my boat is down having a motor built but I've changed my mind..if I decide on that I'll be saving my pennies and having that stuff blasted
