Maintaining Bolt Torque
Old Yeller
Post by Old Yeller »
What's the best way to keep these Rib bolts tight?
Re: Maintaining Bolt Torque
It looks as if your already running a poly nut on there. Were the poly nuts new or did they already have use on them?
I find after use they won’t hold as well FYI.
Tricks we have used on difficult applications have been to use a commercial thread lock like LocTite. The Red #271 is a permanent thread lock compound. If it is the nut coming loose and not bolt stretch, the #271 product will stop it.
Another less intrusive trick is to put a smear of High Quality RTV sealer such as Permatex high heat on one side of the threads and tighten it down then allow 24 hours to cure. Make sure the bolt and nut are clean and dry. The objective is for the sealer to bond and created a filler in the threads and barrier to backing off. Put a little up under the nut after tightening also. Just a pea size amount and wipe the bolt and nut base.
I suspect part of the issue is that the nuts can’t torque flat as they are drilled in at an angle so any flex is working to mechanically loosen the nut. It they were flat the added surface tensions would hold better.
Old Yeller
Thank You!
Anyone else have this "S" Section Rib bolt up issue?
Post by Slidin Gator »
You need beveled I-beam washers to level out under the nut. Normally you drill the hole straight and put them under the I-beam flange, but they should work under the nut for the angle the holes are drilled at.
McMaster has them in SST and Aluminum.
https://www.mcmaster.com/wedge-washers/
Old Yeller
That should do the trick! THANK YOU!
Your welcome Yeller. Not that it matters to you much more much but here's the skinny in case it helps someone select metal for a build.
You didn't get many responses because most boats are built with beams and channels made to "Aluminum Association" standards, which have constant thickness flanges, easy to bolt to. Your beams are "American Standard" which match steel shapes with tapered flanges. The tapered flange is the most structurally efficient, using the least amount of metal for a given strength, they have their place and they are saving you a few pounds. But as you show, the taper creates other issues. Your about to add back the weight savings in washers. :banghead:
Old Yeller
I appreciate the help GREATLY! I'll call McMaster Monday and see if they can get me 110 5/16" in 316SS. I doubt CG will let me get away with 18-8 or an unk ali spec. Thank You Again!
Old Yeller
The brackets have complicated the "wedge washer" theory with a taper that is 90* offset from the crossmember taper :banghead:
