500 caddy with 40 series flows
A discussion on ways to reduce it.
cummins diesel power
Postby cummins diesel power » Sat Jan 15, 2011 11:59 am
Thinking of putting some 40 series flowmaster's
on my boat. Has headers, down to pipe then mufflers,
I have a 500 caddy. How will that set up sound with
the flows. I want kind of a deep, kind of mean sound.
not looking for loud tho
15x7 1974 airgator,500 cadillac dd,74" q series sensenich prop, 1/2" uhmw poly.
18x8 2001 panther, 502 chevy, 2 to 1 century,3 blade 78" stump puller, 1/2" poly
Ruagatr
Re: 500 caddy with 40 series flows
Postby Ruagatr » Sat Jan 15, 2011 2:51 pm
I did this...its loud! Try the 50's....or the stainless 3" summits. The dynomax are also good compromise....
Maddog
ffcracker
Postby ffcracker » Sat Jan 15, 2011 6:40 pm
2.5 silverlines with a 72 q prop, yes its loud on the exaust when you leave from dry ground, but when you move that kind of air anything will be loud.
A RESENTFULL CITIZEN OF A DICTATORSHIP CALLED alachua county
honky440luv
Postby honky440luv » Tue Jan 08, 2013 8:49 pm
i have super trapps out the transome on a combee hull its quite but whene standing behide it sounds good
Postby Deano » Tue Jan 08, 2013 10:16 pm
I've run Flowmasters, Magnaflows and have ended up using the Hush Thrush mufflers for pretty much the reasons you stated, although my primary concern was with quiet.
Mine has the reputation for being the quietest boat around here.
Maybe I should mention they are mounted to the headers (even though that won't work, bla bla bla).
For DD RPMs this doesn't really present a problem, with a box I would mount them differently.
It will get loud if you drive it loud, but if you're being mellow it very readily co-operates.
Return to “Airboat Sound”
