Loud
A discussion on ways to reduce it.
brazosriverrats
Loud
Post by brazosriverrats »
I have a Pathmaker with a 454, 2 to 1, 3 blade sensenich prop. What can I do to quiten it down?
farmboy
Re: Loud
Post by farmboy »
brazosriverrats wrote:I have a Pathmaker with a 454, 2 to 1, 3 blade sensenich prop. What can I do to quiten it down?
What series prop is it?
brazosriverrats
Re: Loud
H series.
gso480jr
Re: Loud
Post by gso480jr »
Use the Q, it will whistle at you. :lol:
akblackdawg
Re: Loud
Post by akblackdawg »
Which sensinich prop do you have? Bud
farmboy
Re: Loud
Post by farmboy »
brazosriverrats wrote:H series.
The H series are loud props... It seems like with the gearbox you would be swinging a reduction prop...???
skinny99
Re: Loud
Post by skinny99 »
More ratio and more prop. Slow tip speed and lots of pitch is the key to quieting the that part of the equation. 2.68 and some NGR's set at about 5200 WOT would be quiet. Then some large automotive mufflers, non flowmaster style. You want something that is actually designed to really quiet the engine down. Magnaflow makes some that are fairly well built.
Return to “Airboat Sound”
