Shoulder Surgery
Other news of interest to the airboating community.
Shoulder Surgery
Post by kwanjangnihm »
Has anyone had this surgery? Dr. is recommending it - thanks
Acromioclavicular Joint Arthritis
If it becomes inflamed or arthritic, it can produce pain and reduced shoulder function. The pain is typically felt directly over the acromioclavicular joint, at the top part of the shoulder, which worsens when using your shoulder, often when lying on your shoulder and when crossing your upper limb across your chest. The symptoms are often recurring or persistent.
Should the above fail to improve your symptoms, then surgical removal of the joint (acromioclavicular joint resection) is an excellent option to improve your shoulder. Approximately 5 to 7 mm of bone is removed from the outer edge of the clavicle, leaving the important stabilising ligaments intact and any rough areas of the acromion are removed.
The operation is carried out under general anaesthetic and performed arthroscopically using three to four small arthroscopic incisions. It is common to perform a subacromial decompression at the same time.
barhopper
Re: Shoulder Surgery
Post by barhopper »
Following. That may help mine.
radtech
Post by radtech »
Haven't had it, but it's a relatively minor surgery. It can definitely help, depending on your condition
Post by Slidin Gator »
Never had that surgery, but you have to weigh the risk, is it your rudder stick or your shooting arm? You can always learn to use foot steering, but learning to shoot left handed is tough for an old dog with Arthritis. :cheers:
OneBFC
Post by OneBFC »
Man, I might have an idea where that damage came from....
All joking aside, I hope you find relief and recover fully. Arthritis is a mean and miserable monster to live with.
-Russ
lilly-Pad
Post by lilly-Pad »
OneBFC wrote:Man, I might have an idea where that damage came from....
:stirpot: :D :D oh that was just wrong but so dam good .well played
12 ft Don Davis / 0470 conv / 68 NGQ , A.A.O.F member
Best laid plans of mice and men, wont always get you laid.............
:lol: :lol: :lol: :lol: :lol:
LMAO!! :violent1: :toothy7:
And yes it is my left shoulder!! :rebel:
Return to “Other Important News”
