continental 220 gpu
BR549
continental 220 gpu
Postby BR549 » Tue Jun 17, 2008 12:16 am
Hello everybody,
I'm very green to this, just got a 220 gpu, wondering if anybody knows where i can get hold of a shop/engine manual or some kind of info about the engine. Or a www dot com address, anything would be greatly appreciated. Not lookly to tear anything down, engine runs great, just something to learn more about it. Just want to kept that CONTINENTAL running strong.
Thank ya,
BR549
AIRBOATS are like a good pan of gravy, they make it all good.
GOD n Country
okie
Re: continental 220 gpu
Postby okie » Tue Jun 17, 2008 12:40 am
Hello there, this is okie. You can order the complete manual from AIR CRAFT SPRUCE. aircraftspruce.com
If you do not have the OIL TEMP GAGE, AND CYLINDER HEAD TEMP GAGE, AND A AIRCRAFT TACH FOR THE CONTINENTAL 220 GPU THEN YOU CERTAINLY NEED TO GET THEM. ANY OTHER INFO. YOU NEED FEEL FREE TO PM ME, I WILL TELL YOU THE WHERE AND WHAT'S FOR THAT ENGINE.
okie
Airboating Okie
Duckman
Postby Duckman » Tue Jun 17, 2008 4:54 pm
Okie, I also have a 220GPU but I dont have any head temps on it; were do they install at?I dont recall seeing any place on my motor for them. Do you monitor all 6 of them? If so what do the gauges look like and were do I buy them, sorry for all the questions but I am new to this and have alot to learn.
Island Style
Postby Island Style » Tue Jun 17, 2008 5:28 pm
Duckman I am in the same boat as you. I just installed the oil temp gauge and i am not sure about the cylinder head temp gauge. Okie and help on this???
gatorfrog
Postby gatorfrog » Tue Jun 17, 2008 9:59 pm
cylinder head temp. gages etc. can be found at most Voltswagon shops good luck, BUT YOUR BEST BET IS TO REED THE ARCHIVES OF '220 GPU " ON SOUTHERN AIRBOAT! :mrgreen:
Reddfin
Postby Reddfin » Tue Jun 17, 2008 10:30 pm
Welcome BR549
We can steer you in the right direction and some members may be closer than you think. Where are you bud?
Regards,
Tony
Proud and (again) current member of the "Four Banger's Club"
Whitebear
Postby Whitebear » Tue Jun 17, 2008 10:40 pm
I was in a tossup between CHT and EGT gages on my O360. The CHT I got from Aircraft Spruce is so simple to install anyone can do it. the sensor just goes under the sparkplug like a washer on the hottest cylinder and the gage is standard panel mount size and you can connect the two with plain 18 gage wire. The EGT requires a thermocouple be mounted in the exhaust gas stream of the hottest cylinder. It has to be securely mounted, and there are several methods to do this. The EGT gage will give a quicker response but the CHT is simpler and will still show the info you need. Browse http://www.aircraftspruce.com/menus/in/chtgauges.html
Scotty
Des Moines Boater
Postby Des Moines Boater » Wed Jun 18, 2008 8:52 am
I wouldn't run the boat without a CHT gauge. Get the 18mm spark plug sensor and be sure you use a copper aircraft washer with any auto spark plug. I monitor all six cylinders but you only need one cylinder to see what is going on. Monitor number 3 or number 4 cylinder. They get the hottest and keep the temps at 450 or below and you will keep that engine running a long time. The max temp for those cylinders is 500 degrees, so, never go above that for any reason. If you don't have a gauge you don't know if you're cooking those cylinders.
13' 6 Lazer, 383 SBC 425 hp, 2.7 Ballistic, 3 blade 80 NGR
hmgm123
Postby hmgm123 » Wed Jun 18, 2008 9:04 am
Des Moines Boater wrote:I wouldn't run the boat without a CHT gauge. Get the 18mm spark plug sensor and be sure you use a copper aircraft washer with any auto spark plug. I monitor all six cylinders but you only need one cylinder to see what is going on. Monitor number 3 or number 4 cylinder. They get the hottest and keep the temps at 450 or below and you will keep that engine running a long time. The max temp for those cylinders is 500 degrees, so, never go above that for any reason. If you don't have a gauge you don't know if you're cooking those cylinders.
That is real good advice.
Geoff
BR549
Postby BR549 » Wed Jun 18, 2008 11:24 pm
okie, gatorfrog, reddfin, whitebear, des moines thanks for the info, CHT is the one i do not have. From what i gather, it says like you can pick the side you want to monitor. 3 or 4 or both, installing them looks pretty basic.
Thank yall again,
BR549
GOD n Country
okie
Postby okie » Thu Jun 19, 2008 2:41 am
gauge and i am not sure about the cylinder head temp gauge. Okie and help on this???[/quote]
Ok thanks. I will put a stop on my order DM and change it to a different gauge. I changed my order and ordered a Mitchell CHT Gauge 100-600 pt# 10-25070and with a Lead Mitchell 10" CHT Lead pt# 10-25185. I fired the engine today and let it run a little while. I wasn't checking for Temps, just wantedmy Oil Pressure was. So, at idle of 500 RPM oil pressure wa and reved up to 1500 Oil pressure was reading a steady 70, this is good I think. What say you.
THIS IS FROM A POST THAT I MADE BACK IN JANUARY. GAGES ARE FROM AIRCRAft spruce, and here are the parts numbers I will also post pictures in the 220gpu article aircraft only so you may see where to attach cables.
okie
The above is a post that I made back I think in January conserning the gages. The parts numbers are also listed in this statement. Both of these gages were purchased at Aircraft Spruce. The Aircraft Tach was purchased at Classic Airboats, on all gages you must state length of cables for all sending units. I have included pictures on the installations of each, and a picture of the module I built and installed the gages themselves. The module is mounted on the seat back of the passenger seat.
okie
airboa1 003.JPG (231.46 KiB) Viewed 4721 times
airboa1 002.JPG (222.49 KiB) Viewed 4716 times
airboa1 001.JPG (178.99 KiB) Viewed 4711 times
Airboating Okie
okie
Postby okie » Thu Jun 19, 2008 2:44 am
The other 2 pictures.
okie
airboat1 024.JPG (238.44 KiB) Viewed 4704 times
airboa1 004.JPG (205.76 KiB) Viewed 4701 times
Airboating Okie
okie
Postby okie » Thu Jun 19, 2008 2:49 am
I hope this helps you guys, you can print the pictures off of here. Also if you want a manual for your 220 GPU, you can order them through Essco aircraft manuals, they are cheaper than Classic Airboats. But I don't know if they are the exact same manual. I got mine through Classic Airboats.
okie
Airboating Okie
brightlights
Postby brightlights » Sat Nov 03, 2012 8:41 am
good stuff...Is there a way I can flag this post for future reference.
exxon
Postby exxon » Sat Nov 03, 2012 10:22 am
were you trying to find an available pdf manual online? Come on guys, it is on your forum
http://www.southernairboat.com/pdf/airc ... Manual.pdf
Alumitech 7136 IO-470-J
gso480jr
Postby gso480jr » Sat Nov 03, 2012 10:44 am
exxon wrote:were you trying to find an available pdf manual online? Come on guys, it is on your forum
x2 exxon.
gpu rick
Postby gpu rick » Sat Nov 03, 2012 1:40 pm
I have the manuals in stock ready to go. 30.00 each
Rick
Barry830
Postby Barry830 » Mon Nov 05, 2012 8:26 am
Users browsing this forum: Keeth1123 and 7 guests
