GSO-480 starter and alternator kits
TIGO541
Post by TIGO541 »
Who else makes this other than AIR-TECH? Ive seen an automotive alternator utilizing the factory spot on this motor before. Who makes that and is there a 12volt starter that utilizes the factory spot also? AIR-TECH is nice but expensive and i would like to keep less back there by the prop. I also need who makes the tach setup that bolts on to this motor. Any help would be greatly appreciated thanks.
13-6x7-6 Hamant Ultra-lite,Custom TIG Stainless rigging,1.7 Rotator,Supercharged 480,Electronic Ignition,80 inch 3BLD R,B&S trailer
jessejames
Re: GSO-480 starter and alternator kits
Post by jessejames »
I run an aircraft 24 volt starter , 2 small 12 volt batteries , and used the spline off an old aircraft alternator , and welded it on a pivoting / sliding shaft and put it on a 12 volt GM alternator . If u do this it will work , but you can only charge one battery at a time, unless you get a distribution charging deal ( sorry cant remember the name ) they r available at some boating stores !.......... Not sure if that helped you at all but thats what i have and it works well .
U name it I race it !.......... I just wanna go fast ! I twist my A/C like a small block !
casper
Post by casper »
I MAKE THE STARTER KITS FOR THE GO AND GSO 480 540 GEAR BOX AND SPOOL KITS FOR AIR TEC I SELL ALL THE THOSE KITS
FOR THE SC AND NON SC ENGINES AIR TEC SELLS THE REST
THE KITS ARNT THAT BAD CONSIDERING WHAT YOU GET YOU CAN PM ME FOR A PRICE
THE 24 VOLT WORK GOOD BUT THERE HEAVY AND SEE WHAT THEY COST TO GET ONE AND OR REBUILD ONE ANY WERE FROM 300 TO 800 THE KIT IS LESS THAN THAT
ALSO MAKE THE INTAKES FOR THE SC'S
MOTOR MOUNTS
AND CHROMING ETC
ALL IGSO,GO AND LYCO STARTER KITS E185 E225 CONT STARTERS,ALT BRACKETS,AND KITS
CUSTOM HEADERS PROP ADAPTERS AND ASSCY GSO CARB WORK REBUILD GO BOXES WELD FLANGES,
CASES DECKED ECT PORT,POLISH CYL ALSO VALVE JOBS ECT I MAKE ALL AIR-TEC KITS
BULLET
Post by BULLET »
TIGO541 wrote:Who else makes this other than AIR-TECH? Ive seen an automotive alternator utilizing the factory spot on this motor before. Who makes that and is there a 12volt starter that utilizes the factory spot also? AIR-TECH is nice but expensive and i would like to keep less back there by the prop. I also need who makes the tach setup that bolts on to this motor. Any help would be greatly appreciated thanks.
Diamondback sells the tach kits.
mowmoney
Post by mowmoney »
jessejames wrote:I run an aircraft 24 volt starter , 2 small 12 volt batteries , and used the spline off an old aircraft alternator , and welded it on a pivoting / sliding shaft and put it on a 12 volt GM alternator . If u do this it will work , but you can only charge one battery at a time, unless you get a distribution charging deal ( sorry cant remember the name ) they r available at some boating stores !.......... Not sure if that helped you at all but thats what i have and it works well .
This is what I need do you have a pic of it where can one find the spline you are referring to.
SO540 AV on 13'6" Diamond back
nunook
Post by nunook »
Faria makes a sending unit which bolts right onto where the cable would and you can utilize a electronic Marine Tach
Faria Diesel Tach Sender.
http://www.boatersland.com/90901.html?g ... gQod_DUFLw
2006 Floral City 14' Deckover Lycoming GSO-480
bignasty1
Post by bignasty1 »
Casper, would you please PM me or give a call when you get a chance. 321-265-2234 I'm looking for a starter/alternator kit, and a shortened intake for a GSO 0480 with gearbox, thank you :rebel:
bignasty1
Post by bignasty1 »
Casper I messed up my number its 321-265-2233 thanks
krazymatt
Post by krazymatt »
Casper passed away couple years ago. Get ahold of Abner @ Elite Airboats. (863) 261-2340
bignasty1
Post by bignasty1 »
Sorry to here that..... Thank you for the info. Merry Christmas
