more help with 0-470 timing
GMAC 76
Post by GMAC 76 »
i now find out that this 0-470-15 has been fitted with 520 cyls so do i time it as an 0-470 or a 520 the timing on the 470 is 26 i believe the 520 timing is 22 thanks again sorry to be a pain but i dont want to mess up
bbstimey
Re: more help with 0-470 timing
Post by bbstimey »
i've got a 470 that called for 26deg. but mine liked 24 better. i'de try it there you should go with 470 #s cause thats what the cam, case, mags, etc. are
14'x8' JB hull w/Stingered GO-480 w/ electronic ignition and 3 blade 80" R
GMAC 76
Post by GMAC 76 »
I timed her to 24 on both mags and it runs and starts great thanks!
