220 g.p.u. spark plug gap
tater99z71
Post by tater99z71 »
I'm running champion d-16's in my 220...can someone tell me what to gap my plugs at? Thanks
Larry
Re: 220 g.p.u. spark plug gap
Post by Larry »
I like to run around .018" gap..... most gpu's seem to start and idle better with a tight gap.
Larry
pirate
Post by pirate »
That's due to the fact that most non electronic mags make a small spark at lower rpm. 18 to 22 thousands works for most aircraft engines.
Bigtom64
Post by Bigtom64 »
The overhaul manual calls for Autolite part No. BR8S Gaped @ .033” to .037”
Bigtom64
Post by Bigtom64 »
arcticman
Post by arcticman »
What mag aircraft or gpu ??
swamp runner
Post by swamp runner »
i set mine at .25 . you need a little bit bigger gap on those oil blowing engines.to little of gap and they'll clog with oil and not fire.just my exp.
12' HAMANT ULTRALIGHT - 180 LYCOMING - 68" CYPRESS SERIES
Bruce
Post by Bruce »
i ran my 220 at 35 thousanths worked great and in an ac motor 28-30 works good
12 foot Mamba "The Underdog"
crackercwboy
Post by crackercwboy »
I always gapped at 35 also
arcticman
Post by arcticman »
rotors and distributor blocks last longer with 018-022 :mrgreen:
MYDIXIEWRECKED
Post by MYDIXIEWRECKED »
.018 for many reasons...
THOUGHT FOR THE DAY
Lifetime member NRA
twister69z
Post by twister69z »
ditto MYDIXIEWRECKED
Twister69z
R L Williams
Post by R L Williams »
Twister69z
"GRASS SCOOTER"
Member of the over the hill gang.
United Sportsmen Airboaters Alliance.
NRA life member.
jasond
Post by jasond »
where can you get the autolite BR8S at.
MYDIXIEWRECKED
Everyone runs their own plug sthat they like. I run Nippodenso L14U's my self(or I did). Other numbers are champion d16 (normal engine) d21 (oil burner), c87 ac delco, a6 I think is ngk, there are a few more too.
THOUGHT FOR THE DAY
Lifetime member NRA
GMAC 76
Post by GMAC 76 »
JASOND THE B8RS plugs were the oem plugs on the gpu they are an aircraft style plug with an automitive type electrode el reno avaition in el reno ok used to sell them as surplus parts for 6 bucks a piece but if you dont have aircraft plug wires they wont do you much good and i am not sure el reno still has them they told me they were getting hard to find 2 years ago
MYDIXIEWRECKED
put some solid core automotive wires in the caps and run auto plugs they are way more available and cost effective! :D
THOUGHT FOR THE DAY
Lifetime member NRA
