220 ideling rpm's
JAMES
220 ideling rpm's
Post by JAMES »
whats a average idel or ideal rpm for a 220
and is it normal for the rach to jump around a lil (mech tach)
Tony480
Re: 220 ideling rpm's
Post by Tony480 »
600-700.how much is it jumping around?
Des Moines Boater
Post by Des Moines Boater »
I run mine around 450 to 500 rpm at idle. 600 is fine but it does push the boat at that speed. The tachometer will jump around a little if it is worn out, so, it is not normal. I have a new tach on my boat and it is rock steady. Nothing wrong with one bouncing around a little if you can't afford a new one.
13' 6 Lazer, 383 SBC 425 hp, 2.7 Ballistic, 3 blade 80 NGR
goldhunter_2
Post by goldhunter_2 »
I set my ideal at 400 to 450 rpm's
:rebel:
dynaairglide
Post by dynaairglide »
I bought a new tach fo my 220. It had some grease in the housing when I bought it. When I started the engine, the tach would jump up and down about 400 rpms. I really packed some grease in the cable housing, and it stopped the tach from jumping. My 220 will idle at 200 - 250 rpms. Has a nice lope to it at that speed.
Be American... Buy American!
Bruce
Post by Bruce »
around 600 is where mine was
12 foot Mamba "The Underdog"
wrenn231
Post by wrenn231 »
Really should set the idle up to about 700 RPM anything less will cause the impulse to engage constantly, which will wear it out over time.
Aircraft A & P Licensed
twister69z
Post by twister69z »
600 rpm idle seems the best .
Twister69z
JAMES
Post by JAMES »
the tach (was) jumping a lil when i installed it yesterday it is new and its a isspro the tach stoped jumping today after running it some more it idles around 5.5-600 rpms
the oil pressure is around 45-50 at idel everything seems good ill hit the water maybe this weekend i havent bought a prop yet im useing my buddys spare woodie at this time thanks agin for the info
