help with IO-470 timing
GMAC 76
Post by GMAC 76 » Fri Jul 02, 2010 2:40 pm
what is the best timing degree to set for an IO-470 using automotive fuel our 520 tag says 22BTC but the tag on the 470 is missing thanks for the help
hostile
Re: help with IO-470 timing
Post by hostile » Fri Jul 02, 2010 5:08 pm
Depends on which dash number engine. It varies from 20BTC to 26BTC. I'm showing an IO-470G with 8:1 comp using 91 octane at 26BTC. There is a IO-470H at 8.6:1, 100 octane at 20BTC and an I0-470J with 7:1, 80 octane at 22BTC.
glades cat
Post by glades cat » Fri Jul 02, 2010 5:52 pm
Speedwheelie set my io-470-j @ 25.
gruprgetr
Post by gruprgetr » Fri Jul 02, 2010 10:14 pm
what gladescat said :bounce: :bounce: :bounce:
(SWAMP GAS)
IF YOU PISS SOMEONE OFF MEANS THEY HEARD YOU
AIRBOATS DONT SPREAD HYDRILLA
AIRBOATS DONT CAUSE ANIMOSITY- PEOPLE DO!!
PROTECT YOUR FUTURE WEAR A PFD AND VOTE!!
on a dark calm night ya can hear the cryaker scratchin on your poly
