0540 on av gas
gariverrat
0540 on av gas
Post by gariverrat » Tue Dec 21, 2010 8:56 pm
Is it necessary to run av gas in the 054 or can you get by with the highest octane from the street pumps? Thanks in advance for feedback
Roads......., What roads? Where we're goin we don't need no roads.
Daddy Dave
Re: 0540 on av gas
Post by Daddy Dave » Tue Dec 21, 2010 9:01 pm
Different 0-540s require different fuels - compression ration usually determines which fuel runs best.. Straight valve or angle valve? Only the 230 hp version was designed to run on leaded auto gas. The Recreational Fuel now being sold at many marinas is 93 octane and does not have ethanol. AV gas will run much cooler and it has an indefinate shelf life.
A I R B O A T
fl cracker
Re: 0540 on av gas
Post by fl cracker » Tue Dec 21, 2010 9:06 pm
not to mention av gas will give better performance!
" I have two guns...
One for each of you "
2017 Al David / stroked LS
gariverrat
Re: 0540 on av gas
Post by gariverrat » Tue Dec 21, 2010 9:14 pm
As you can probably tell, I am in the read/study [phase before buying a boat. What is the difference (which is best or most used) between straight valve and angle valve. Thanks guys :usa:
BradWeihrauch
Re: 0540 on av gas
Post by BradWeihrauch » Tue Dec 21, 2010 11:32 pm
Diesels run on Diesel....Flammable on flammable(combustable)...Compression on compression.....Aviation on aviation.....all BS aside, if you fill a 30 gallon tank, and you are considering Av/Reg gas, and let's say that difference is $3.60 vs. $2.90, and let's say the tank is dry, that means that 30 gallons will cost you $21.00 difference between pump and AV. Then what the heck are you thinking, either drink a cheaper beer, quit dipping, quit smoking, or PAY the damn couple of bucks to protect your $10,000+ AV/motor. If you have to think about $21 over the course of a whole weekend, you need to sell your damn boat and buy a Kayak............
glades cat
Re: 0540 on av gas
Post by glades cat » Wed Dec 22, 2010 12:38 am
You can buy the cheaper mogas and add:
-Octane booster, a good one, because your burning crap...$8.00 :shock:
-Lead Additive, because your valves and seats take a beating when you burn crap...$8.00 :D
-Sta-bil, because crap sours quickly and is hygoscopic (absorbs water)...$8.00 :lol:
Mogas has many streams of additives to give it particular characteristics, like clean-burning. The more additives, the less fuel.
Avgas has the "good stuff" you want in Gasoline, mainly straight-chained Alkanes (Parafin).
You want less Benzene, Alcohol and aromatics in your fuel for max octane rating.
Gasoline is supposed to "deflagrate" not "detonate". Controlled combustion, not detonation.
or...just burn Avgas and forget the additives.
If you burn Mogas, mix some Avgas in with it and save a couple bucks.
I've run Mogas, just not straight or all the time.
You can survive on McDonalds and vitamins...but you really need meat and potatoes.
Southern Style
Re: 0540 on av gas
Post by Southern Style » Wed Dec 22, 2010 8:27 am
I agree with all posts... It is only about $10-$12 differnece when you get gas... I never run a full tank anyways.. Added weight and I never use but about 1/2 tank anyway... And if the $12 is gonna stop me from running, I need to pick up another hobby...........
AvGas will run cooler...... and there is no replacement for taking care of your engine.. The most expensive part on your boat.................
KRVSA Member
SJRAA Member
KCCO
rac1boat
Re: 0540 on av gas
Post by rac1boat » Wed Dec 22, 2010 7:16 pm
Enjoy all the avgas you can because it want be here long! EPA pressuring hard to start phaseout of 100LL by 2013!
gariverrat
Re: 0540 on av gas
Post by gariverrat » Wed Dec 22, 2010 10:42 pm
Thanks guys, I'm learnin,..
