What prop for my 180 Lycoming??
- Site Supporter - II
- Contact:
The prop that came on the boat when I bought it is an old wooden 68x36 with metal leading edges that make me nervous when I spinn it up. I really need to replace it before it comes apart and hurts someone. Can y'all give me some insight on the modern props available that will work well with my little 4-banger? I am looking for low end push more so than the top end speed. Thanks in advance...
your pal,
josh
your pal,
josh
- Jabroni
- Site Supporter - III
Re: What prop for my 180 Lycoming??
i run a 70" q on a 160hp h2ad and my dad just got the new 70 NGH don't think he tried it yet but dan the airboat man said that's the new way to go
Just got down in DX land, DOOFUS standing by reading the MAIL
- Swampthang
sensenich ngh gets my vote.... 2nd place: Q series
12'by7'8" Alum Home Built Full Deck, GTSIO 520 GPU Conversion. NOS, Roller rockers, XDI Electronic ignition,72"NGH 2 blade.
I am looking for the same info., how does the 69 whisper tip compair to the Q and the NGH? What are the weight differences and I also don't have much room from my fly wheel to where the rudders begin. I run a warp drive now and I have maybe 5-6 of clearance to where the rudders start. I am looking for the best all around prop and great low end push. I am also not trying to high jack this thread, just didn't want to start the same topic over.
- Site Supporter - IV
I would vote #1 NGH #2 Q , I have ran both on four cly lycoming and I really like the NGH!
Freedom is Abridged by Silent Encroachment.---James Madison
I HAVE THE 69" NARROW BLADE WHIPER TIP ON MY 160 AND IT PUSHES TWICE AS HARD AS MY POWERSHIFT DID. GREAT LOW END PUSH AND AN EASY HUB DESIGN. IT IS CHEAPER THAN THE SENSENICH AND I AM VERY HAPPY WITH IT. THEY ALSO OFFER A 30 DAY MONEY BACK GUARANTEE IF YOU ARE NOT HAPPY WITH IT. THAT IS A HARD DEAL TO PASS UP IN MY OPINION. I WISH I WOULD OF PUT A 70" BECAUSE I CAN SWING IT NO PROBLEM WITH MY STOCK 160. I TALKED TO WALLY MOORE AND HE SAID THEY ARE RECOMMENDING A 72 NARROW BLADE WHISPER TIP FOR 180'S. HE HAS THE BEST PRICES ON WHIRLWIND PROPS. 407-422-4318 IS HIS NUMBER. YOU WILL NOT GO WRONG WITH THE SENSENICH PROP EITHER SINCE THEY ARE GREAT PROPS ALSO. I HAVE NOT PERSONALLY RUN ONE ON MY 160 SO I CANNOT GIVE ANY ADVICE ON IT.
I LOVE THE SMELL OF AV GAS IN THE MORNING. IT SMELLS LIKE..... VICTORY
- Contact:
I'm getting some quotes for the NGH. I will let y'all know what I end up with and how much more push I get out of it compared to my beat up, old wooden prop. Thank you all for your input!
your pal,
josh
your pal,
josh
- Jabroni
Call Dan the man
you will like the ngh
- Southern Airboat Member
I love my narrow whisper tip on my 160. Amazing push, great snap, and high top speed. I couldnt ask for anything else. Really makes me look back and make sure its still a 4cyl sometimes lol
When in doubt floor it!
11'8 Step 0-470-11....
- Site Supporter - VIII
I love to sale the ngh. It is making some happy customers
. It is the prop right now on the scene. It has the I beam gusset the new style webbing in the blade along with the winglet at the tip. Its a very sexy blade. It allways drops the customers cruise by 150 to 250 rpms and pics up top end. It is also quieter that the q and other look alikes. The superior hub and blade design makes this prop worth a little extra.
I will put this prop up against whatever you are currently running and give you your money back if you don't like it..thanks dan
Sensenich propellers dealer.
Airboat consulting.
Dan@352 812 2239
Airboat consulting.
Dan@352 812 2239
- BAD ADDICTION
- Contact:
I have a 180 and I tried a warpdrive ,wood,q,and Walter walker Sig.nature series. I like the waterwalker cause it seems to have more push.jmo.
WE NEED IT WE BUILD IT!!!
Geared supercharged 0480 on 13 Hamant swinging 78" r blades. !!!
- Contact:
I just ordered the 2-blade 70" NGH today. I can't wait to put it on and try it out.
- Contact:
yeah your boat has good speed but just not enough to keep up with mine hahahahahahahairboat470 wrote:I love my narrow whisper tip on my 160. Amazing push, great snap, and high top speed. I couldnt ask for anything else. Really makes me look back and make sure its still a 4cyl sometimes lol
.jdeputy09 wrote:yeah your boat has good speed but just not enough to keep up with mine hahahahahahahairboat470 wrote:I love my narrow whisper tip on my 160. Amazing push, great snap, and high top speed. I couldnt ask for anything else. Really makes me look back and make sure its still a 4cyl sometimes lol
Only difference is lol is you dont have to look back and make sure yours is a 6 cyl. You look down...at the gas tank!
YOU GOT ME DANG!!!!!!airboat470 wrote:.jdeputy09 wrote:yeah your boat has good speed but just not enough to keep up with mine hahahahahahahairboat470 wrote:I love my narrow whisper tip on my 160. Amazing push, great snap, and high top speed. I couldnt ask for anything else. Really makes me look back and make sure its still a 4cyl sometimes lol
Only difference is lol is you dont have to look back and make sure yours is a 6 cyl. You look down...at the gas tank!.
How about it C.R. ? Have you ran it yet
- Contact:
All I need is a spacer plate to make the hub sit flush against the flywheel... I am in the process of having one cut at the moment... This weekend looks like it might warm up enough to give it a spin... I'll post my new cruise RPM and my new top speed as soon as I get a chance...
Here is what the spacer will look like...
WAIT !!! don't do that.you need to cut the dowels,like a 1/4 in. off of them. then file any burs off and it will go right on.
12' HAMANT ULTRALIGHT - 180 LYCOMING - 68" CYPRESS SERIES
- Reddfin
I don't know if its right but I have also ground them down a little and made sure they were still straight. Pretty easy to do.
Regards,
Tony
Regards,
Tony
Proud and (again) current member of the "Four Banger's Club"
- Contact:
I agree with yall, making those studs shorter will buy me another 3\8" of clearence at the stern and I NEED it. I had to move the rigging forward about an inch to get it to work. But until then, the spacer works and the NGH pushes the boat great! I didn't know the old wood prop was so out of balance. With the new prop the boat idles much smoother and pushes hard enough to make it through wet sand with ease. Also I gained about 5 mph on the top end and that buzzing noise from the wood prop is gone. I should have done this a year ago! I have it set on the third mark and I can tell the motor is working harder to spin it but seems to do the job quite nicely.
What; if anything, will I gain by putting the blades back to the second mark? Some rpm's sure, but what rpm is the blades "sweet spot"??? It is so easy to adjust the blades, I got to try some other settings and see what happins...
- Contact:
no set sweet spot .. each boat different .. adjust ..try adjust try .. find it quit
set it at 2950 and you will really love it
- Reddfin
plumcrazy wrote:set it at 2950 and you will really love it
Set at 2950 on trailer or on the water? Is that pretty close to just shy of #2 on that 200hp Plum? I guess I could ask Dantheairboatman or DAGWOOD0520 too. I think my very good buddy set mine a little too high. He thinks Continentals (even four bangers) can move mountains.
Tony
