Angle valve 470 vs angle valve 540
jdeputy09
Post by jdeputy09 »
I want to get opinions on the pro`s and cons of both motors. witch one would be the best engine on a hunt boat.
deepsea diver
Re: Angle valve 470 vs angle valve 540
Post by deepsea diver »
It's basicly the chev/ ford thing. They are both great motors. They both suck gas when you put your foot in them.
They both have alot of power, 240 to 300, just depends on model.
Bad thing: they both cost alot of money, sometimes you can get a run out from 4 to 5 thousand, alot of of engine builder will sell you on from 8500 to 10500. Depends on what motor.
To me the gold standand is the 0540. Nothing wrong with a connie 0470 or 0520. If I was going to put out the hard cash for a rebuilt engine I would go 0540.
Now you asked about the hunt boat, I would go sv 0540, a little less power, runs cooler, and they seem to last longer from what I have seen.
It's like asking ,"whats better" blondes, redheads, or burnets. There all good. :D
CONTINENTAL CRACKER
Post by CONTINENTAL CRACKER »
both are good engines. the 540 is 300hp and the 470 is 240-260 hp.i like a continental for the reason of the cams are sumerged in oil and the cracks are solid.plus the continental fuel injection is the best systems :florida:
I WOULD RATHER PADDLE A CANOE THAN OWN A WATERPUMPER
MJD291
Post by MJD291 »
LIKE C.C. SAID THE CONTINENTAL'S HAVE A BETTER CAM DESIGN. THE LYCOMING IS LIGHTER THAN THE CONTINENTAL. THE CONTINENTALS TEND TO BE CHEAPER TO BUY THAN THE LYCOMING. THERE IS GOOD AND BAD WITH BOTH.
I LOVE THE SMELL OF AV GAS IN THE MORNING. IT SMELLS LIKE..... VICTORY
MJD291
Post by MJD291 »
IF MONEY AIN'T A THING GO WITH THE LYCOMING IF YOUR ON A BUDGET GO CONTINENTAL.
grant
Site Supporter - VII
Post by grant »
Have had both....both great motors. Continental seems to be a little tougher. Always went with Lycoming for ease of field repair when I was working them for a living....could have a Lycoming cylinder changed and running before you got the intake system off the Continental :D
For a hunt/recreational boat it's really a matter of preference.
"Don't Taze me Bro"
Duece
Post by Duece »
I have run both, and both kick a$$ in terms of power. Didn't work on the O-540, but did work on the O-470, and Grant is correct. I may be a little biased though, my O-470 still had the damn safety wire on it!!! :o My O-470 was rated at 260 hp @ 2800 RPM's (still had the tag on top of the motor).
Duece
"Welcome to the Dark Side..."
jdeputy09
Post by jdeputy09 »
yea I run a angle 540 currently and love it ,just curious how close the 470 is in performance.
cntry141iq
Post by cntry141iq »
well 70 cubic inches and about 40 to 60 hp difference LOL
bbstimey
Post by bbstimey »
there is a whole lotta 230hp or 250 hp s/v 540s out there not all are 300 hp
14'x8' JB hull w/Stingered GO-480 w/ electronic ignition and 3 blade 80" R
blowme
Post by blowme »
Hey bbbiiittcchh keep what u got and be happy with it u got a fine boat
what we have here is failure to communicate
cfth
Post by cfth »
The 300 hp 0540 is generally an i0540. To get the 300 out of it its usually injected and an angle valve. The standard 0540 is 260 hp and sv . Also as mentionded there are lesser hp's. I would think a better comparison is a 0520. But thats just me and I am not a motor guy. I just run em.
"Alligator Hunters Get More Tail"
Capt. Grayson Padrick
321-632-8995
http://www.centralfloridatrophyhunts.com
Alligator Hunts, Hog Hunts & Osceola Turkey Hunts, Headlights,
Alligator Hunting Equipment & Frog Hunting Equipment
Rich Andrews
Post by Rich Andrews »
you mean to tell me all 540's are not 300 hp?
grant
Post by grant »
Rich Andrews wrote:you mean to tell me all 540's are not 300 hp?
Pretty sure they are only 160 or maybe only 125 :shock:
So many motors that size run circles around them :D :D
"Don't Taze me Bro"
Rich Andrews
better make sure the 470 your looking at isn't one of those less then 250 hp motors they made. If so you need those helicopter pistons to pump em up to 300hp :lol:
blowme
Post by blowme »
:scratch:
Pretty sure they are only 160 or maybe only 125 :shock: :thefinger: :thefinger:
IT TOOK ME A MINUTE BUT I GOT IT :scratch: HAHA ...SMARTASS
MJD291
Post by MJD291 »
MY MOTOR HORSEPOWER IS DETERMINED BY HOW MANY BUD LIGHTS I HAD. IT STARTS OUT A 160 THEN AFTER A COUPLE IT TURNS INTO A 200. THEN AFTER 6 IT IS A 540 AND THEN AFTER 12 IT TURNS INTO A SUPERCHARGED GEARED INJECTED 540. :drunken: :blackeye:
airboat470
Post by airboat470 »
HAHAHAHA. Grant. :cheers: :headbang: . You got that right.
When in doubt floor it!
11'8 Step 0-470-11....
Qwikdiesel
Post by Qwikdiesel »
I happen to like the 290hp s/v myself :D
Keeth1123
Post by Keeth1123 »
So the a/v 470 will hang with the S/v 540?
:old_glory:
Gary S
Post by Gary S »
Motor ain't everything. Boat, prop, how much junk you carry. A 470 is a good motor and is lighter than 540. It also has a great Harley Davidson lope when it's idling.
Keeth1123
Post by Keeth1123 »
Can anyone speak of the performance of the 470 when paired with a 13.5 cottonmouth hull? Not sure on prop but it’s a carbon 2 blade
:old_glory:
riverrat1
Post by riverrat1 »
Rich Andrews wrote:better make sure the 470 your looking at isn't one of those less then 250 hp motors they made. If so you need those helicopter pistons to pump em up to 300hp Image
What's the driffrence in the Pistons
luv2airboatnhunt
Post by luv2airboatnhunt »
Keeth,
My GPU/AV470 conversion will run all day next to a 260 hp SV540
:proud:
AlaskanOutdoorsman
Post by AlaskanOutdoorsman »
I second that question. I'd like to know the difference too!
