What is your "cruising" rpm range?
GeeLeDouche
Post by GeeLeDouche »
I'm trying to figure out where I should be with my cruising rpms, after I get on plane.. So I was curious of what most of you run rpm wise after getting up on step. If you would be so kind to let me know what rpm you run and see good results, I would appreciate it.
Thanks guys!
The Gee
JAMES
Re: What is your "cruising" rpm range?
Post by JAMES »
13 ft glass hull 470 conversion 76" 3 bld h 2 guys around 450-500 pds 1800rpms plain
gblack15
Post by gblack15 »
12 ft Panther Lightening hull LYC 360, 68" 4 bld warp, 2 guys and dog, 1700 rpms plain
Southern Style
Post by Southern Style »
0-470-R Continental, 13'-6" by 7' Hamant hull, 2 blade WhisperTip composite prop, 3 adults cruise RPM's 1900..........
KRVSA Member
SJRAA Member
KCCO
mitchboy
Post by mitchboy »
14 ft glass hull 300hp sbc was running 3500 with 237 gear box went to 2.12 box now i cruise at 2900 2 blade whisper tip
minnow20
Post by minnow20 »
22' aluminium boat levitator motor, 4 blade R's with 2.3 belt reduction no extra weight-3200, loaded down 6 people and hunting gear-3700.
2013 15X8 GTO 427 sbc all aluminum fuel injected. 2.55 gear reduction. 4 blade NGR.
harley
Post by harley »
14X8 GLASS HULL WITH POLY, 383 SBC, 450+ HP , 268 GEARBOX , 80' 3 BLD R SENSENICH..
LOADED 3 PERSONS AND COOLER WITH FULL TANK OF FUEL CRUIS ABOUT 3200-3400 RPM'S IN DEEP WATER.. 8)
THAT'S WITH THE PROP SET AT 3 MARK.. 5500 RPM , WOT...
14x8 Diamondback / SBC Power.
"ALL THROTTLE NO BOTTLE"
Swampthang
Post by Swampthang »
my gpu..1500rpm is the lowest it will stay on plane in shallow water... as far as crusing speed it really depended on my friends and how fast they are going...deep water: 1700-2200rpm is what we uselly cruse at.. that all depends on weight, my friends and how deep it is that day... some i ride with go soooo slow and some like to hall azz every where... :scratch:
12'by7'8" Alum Home Built Full Deck, GTSIO 520 GPU Conversion. NOS, Roller rockers, XDI Electronic ignition,72"NGH 2 blade.
Dough Slayer
Post by Dough Slayer »
13' Laser, IO-520, 72" 2-blade Q, 2 people and a cooler.........cruising at 1700.
Hell no I don't bake cookies........but i'll eat'em!
13' laser, io-520, 6-blade warp.
220hardin
Post by 220hardin »
12x6 alum hull, 220 Gpu single mag power shift prop full tanking gas and one other person around 1750-1800 rpms in deeper water
Cowley
Post by Cowley »
18x8 Alumitech, 8.1 Levitator, 82" 4 blade R, 50 gal. fuel, deep water 3,000-3,200 rpm
18x8 Alumitech / 8.1l Levitator / Century 2.3:1 / 82" Sensenich 4 blade R
SouthRiver
Post by SouthRiver »
By myself and a half tank of av gas, about 1700, 3 people and a cooler about 1900
"It is what it is......and...... "Everything happens for a reason, whether you like it or not......."
New boat is in the works..............
BCAA Member
N.R.A. Lifetime Member
Southern Style
Sure would help if you mentioned aircraft or C/M... I would have thought since you put it in the Aircraft Section, you would be talking bout an A/C motor..............................
Anyways, you got a good bit of numbers now to go by...
KRVSA Member
SJRAA Member
KCCO
Cherpa
Post by Cherpa »
10'6" alum. deck over, Lyc. 0360
1200 - frogging
1200 - 2300 cruising (depends on how fast you want to go)
2750 - hold on
We grow too soon old and too late smart.
cntry141iq
Post by cntry141iq »
35 hp briggs and stratton 1.7 reduction 3 blade 61" warpdrive ... cruises at 2700 ... very light boat
160 lycoming 70 inch whisper tip narrow cruises at 1400 to 1600 depending on water depth on a 300lb all composite stephull ..
now for the kicker ....
if it is an a/c engine your engine rpm and prop rpm is the same .. right ?? no take your engine rpm on the reduction units and divide it by the gear ratio and your gonna find the same basic prop rpms across the board ... hull design load and water conditions will be the minor differences ... just a thought
briggs above 2800 divided by 1.7 equals 1588 prop rpms ... aint that a hoot .. LOL
claywood
Post by claywood »
O290 mechanical lifter (125hp), 11-7 narrow nose fiberglass hull, four blade warpdrive set at 8, one passenger, full cooler and gear, cruises at 1800 rpm
Bubbaj
Post by Bubbaj »
550 hp Car motor 2.38 box 78 in 3 blade 4000 to 4200
cntry141iq
Bubbaj wrote:550 hp Car motor 2.38 box 78 in 3 blade 4000 to 4200
for a cruise rpm that is very high ???? I couldn't afford the gas ...
milo540
Post by milo540 »
Thos guys got it ruff :thumbleft: :thumbleft:
13ft hull stainless rigging single front driver single rear passenger
Igso 480 with a 4bld powershift
Built by Big Bad Customs "Jason wolf"
milo540
Post by milo540 »
This*
hogdoggin
Post by hogdoggin »
11 foot 3/4 deck with 0540 3 blade NGH 1500 to 1600 good cruise speed
