ELECTRONIC INIGITON FOR 0540
chief
Post by chief »
WANTING TO GET SOME INPUT FROM EVERYONE ON ELECTRONIC INGTION FOR 0540 AS FAR AS WHAT EVERYONE IS RUNNING OR BEST TYPE AND WHO TO PURSCHACE IT FROM ANY HELP ON THIS ISSURE WOULD BE A GREAT HELP........
21' AIR RANGER WITH SBC DIRECT DRIVE WITH 68'' WARP DRIVE
yobee
Re: ELECTRONIC INIGITON FOR 0540
Post by yobee »
Send a pm to GKA0540 If Im not mistaken he has built his own kits, and build engines too.
Fat Cat
Post by Fat Cat »
Try Gary Armstrong (GKAO540) on here. He has a good system that he puts together. From what I hear he has very good results on economy and power.
***Edit****
Yobee, looks like we were thinkin the same thing.
13ft Mamba hull
Gary Armstrong 540 UpStack
bbstimey
Post by bbstimey »
electromotive makes a good system, abner at keeners machine shop can tell you all about them
14'x8' JB hull w/Stingered GO-480 w/ electronic ignition and 3 blade 80" R
JT540
Post by JT540 »
get with gary he wil do you right if you need his number pm me and iw ill give it to you! he sets up a very nice system!
chief
Post by chief »
thanks to all that replied ill get in touch with gary armstrong a buddy of mine is having gary build his engine i just wasnt aware that he did eletronic igniton........ always remember to keep the wet side down and the dry side up !!!!!!!!!!!!!!!!!!!
hogman
Post by hogman »
Have been running the old Charlie Bass electronic ignition for 17 years on my 0540. Renewed internal electronic modules after the first 9 years and have had to change more out as time goes by. Overall it's been great but nobody near here can work on them. Would like to find some old discarded systems or new just for parts if anyone knows where some might be. Did get one from Jr Jurnigan. Thanks Jr.
pirate
Post by pirate »
You might try these folks. Also maybe Jeggs.
Pro-Tronics part #'s:
Cap - 022-1602
Rotor Kit - 020-1003
Igniter - Module 4 Marine
Pro-Tronics 1-800-827-3758
I've got a pair setting around somewhere for a 6 cylinder but never used them. What do you think of them? Plug gap?
aherr520
Post by aherr520 »
I have electromotive on my 0520 and does great fuel injection and ignition very reliable
aaof member
TIGO541
Post by TIGO541 »
I have Electromotive XDI and love it! Its triggered by a Magnet and wheel so no gear slop timing lag. Never ran the boat with Mags so not sure on the power or economy gain but it snaps my 80inch R set at 24.7 degrees like its not even there! Im sure the gear box and supercharger doesnt have anything to do with it :lol:
13-6x7-6 Hamant Ultra-lite,Custom TIG Stainless rigging,1.7 Rotator,Supercharged 480,Electronic Ignition,80 inch 3BLD R,B&S trailer
Olf Art
Post by Olf Art »
Believe it or not, WaterThunder has done quite a bit of research and testing on A/C electronics .... both ignition and fuel injection.
hogman
Post by hogman »
Pirate...have been getting my parts from Pro-Tronics. They have been helpful and seem like very good guys. Just would like to have another spare housing. The plug ( Denso ) gap is set at .0040 as per Charlie Bass. They have been as close to trouble free as best you can get and always fire up the engine. I've come home on one mag several times but just change out the ignitors, coil, rotor, and cap. I don't know how to test for the problem so just change everything and get going right away again. Also the engine timing can be done with a regular timing light. I'd be interested in purchasing your stock ones if you're selling.
Thanks for your comment
josh_2562
Post by josh_2562 »
Can y'all post up some pics of your set ups.
dusty burch
Post by dusty burch »
call shane buie he is a dealer for electro air it is all around better 386 972 2586
crackercwboy
Post by crackercwboy »
hogman wrote:Have been running the old Charlie Bass electronic ignition for 17 years on my 0540. Renewed internal electronic modules after the first 9 years and have had to change more out as time goes by. Overall it's been great but nobody near here can work on them. Would like to find some old discarded systems or new just for parts if anyone knows where some might be. Did get one from Jr Jurnigan. Thanks Jr.
Pertronixs is what is in the bass systems, been messing with one here lately. They are on the internet.
GKA 0540
Post by GKA 0540 »
THERE'S A COUPLE PICTURES OF THE SYSTEMS WERE DOING IN MY MEMBER GALLERY, I LIKE THESE A LOT BETTER THAN THE ELECTRO AIR SYSTEMS OR ANY OTHER SYSTEM THAT I HAVE TRIED. NO MOVING PARTS OR GEAR LASH.THIS IS THE SAME SYSTEM THAT ABNER IS USING, I BUY MY COMPONENTS FROM KEENERS(THEY ARE A DEALER FOR ELECTOMOTIVE)IF YOU HAVE ANY QUESTIONS OR WOULD LIKE SOME INFO GIVE ME A CALL. THANKS GARY (561)722-8444
pirate
Post by pirate »
Hogman..sent PM
Qwikdiesel
Post by Qwikdiesel »
Gary can you change the timing on your set up just by turning a dial?
GKA 0540
Post by GKA 0540 »
Qwikdiesel, yes just turn the knob, adjustable from 0-30 degrees. it starts the engine at 4 degrees and then goes to where ever you have the dial set at once the engine rpm hits 400. theres a lot you can do with this system but i suck at typing :? , if you have any questions or i can help you out with anything just give me a call, thanks Gary
B-White
Post by B-White »
GKA 0540 wrote:Qwikdiesel, yes just turn the knob, adjustable from 0-30 degrees. it starts the engine at 4 degrees and then goes to where ever you have the dial set at once the engine rpm hits 400. theres a lot you can do with this system but i suck at typing :? , if you have any questions or i can help you out with anything just give me a call, thanks Gary
What's the price on your complete set-up???
Devil in the Bottle 83 ProMod
Marsh Master Step
Carbon Fiber Rudders by:HAMMERHEAD AVIATION.com
Prop is NOTHING BUT A WHIRLWIND!!!
RAZORX
Bubba
Post by Bubba »
U dont need it so it dont matter. lol
FLIRTIN WITH DISASTER
B-White
Post by B-White »
Bubba wrote:U dont need it so it dont matter. lol
Ya never know,,,,,,,I need all the help I can get....
Marsh Master Step
RAZORX
Bubba
Post by Bubba »
Not after the last race !!! Yall get any faster and I quit.
mwood7800
Post by mwood7800 »
So ball park, whats a system cost, 500, 800.
Any more I would have to stay with my Mags
JT540
Post by JT540 »
its more but its worth it if you want exact prices call gary!
