go-480
mshetters
go-480
Post by mshetters »
Hey i need some input on go-480 got to split case to do bearings ive heard of putting 540 rods in place of the 480s will that work out allright
longshot123
Re: go-480
Post by longshot123 »
if you put 540 rods in it. you will have to put spacer plate's or you will have problems- stroke will be to long- pistons will hit the valve's
