500 vs 600 cfm for 0470 gpu
elviswho
Post by elviswho »
I recently bought an older Panther airboat with a 0470 gpu motor. I have had to have the cylinders redone and it was recommended that I switch from the Zenith carb. to a 500 cfm Holley. A friend has since recommended going to a four barrel like a 600 or 650 cfm Holley. How much is too much carb. for this engine. I am running a thin blade three blade composite prop.
Buck Thruster
Post by Buck Thruster »
The 500cfm Holley has proved to be the best direct replacement carburetor for the Zenith on single mag stock 470 gpu's.
Ride with pride. It's not illegal to be an airboater.
rjonesboy
Post by rjonesboy »
A 470 ci engine is not capable of flowing more than 500 cfm at 3000 rpm. there are several cfm calculators available on the net if you want to check 4secondsflat.com is one.
Waterthunder
Post by Waterthunder »
The four barrel looses to much velocity the 500cfm two barrel is much more responsive plus I'm constantly told the four barrels drop valve seats in 220's.
THE PROOF IS IN THE PROP!
http://waterthunder.com/
321-508-5316
Skeeter
Post by Skeeter »
The jetting on the 500 Holley is very easy to change and in my opinion is the best carb for the 220.
elviswho
Post by elviswho »
Thanks for all the input, sounds like the 500 cfm two barrel is the better choice. Does anyone want to trade a two barrel intake for a four barrel intake? A friend of mine just dropped of a four barrel intake he had, but it sounds like I better wait for a two barrel setup.
MadSid
Post by MadSid »
elviswho wrote:Thanks for all the input, sounds like the 500 cfm two barrel is the better choice. Does anyone want to trade a two barrel intake for a four barrel intake? A friend of mine just dropped of a four barrel intake he had, but it sounds like I better wait for a two barrel setup.
Just pick up a 4 to 2 adapter
elviswho
Post by elviswho »
That's what I will end up doing, just thought maybe someone might need a four barrel setup and this would end-up helping us both.
elviswho
Post by elviswho »
Can anyone tell me what the cfm of the zenith GPU carb. is.
MadSid
Post by MadSid »
elviswho wrote:Can anyone tell me what the cfm of the zenith GPU carb. is.
Do a search on GPU I saw a spec chart for all the motors on here a while back .
Red Dwarf
Post by Red Dwarf »
I bet it's less than 500
swampjet
Post by swampjet »
elviswho,
If you go with the 500 2bbl, I would recommend changing the power valve to a 10.5 and the jets to 77. On either the 2bbl or 4bbl make sure the rise of the intake is about 3.25 inches from the top of the intake where all the tubes come together and the bottom of the carb mounting plate. Hope this makes sense.
Bob
Another Day in Paradise
elviswho
Post by elviswho »
Thanks for the info. If i use the four barrel intake I'll have at least that much room if not more with the two barrel adapter plate.
