Need mags for C-65 or C-85
ebwayllc
Post by ebwayllc » Wed Apr 18, 2012 9:08 am
I have a c65 with bad mags full of water. I need to make sure the engine runs before having them rebuild any suggestions on how to do that or does anyone have one i could rent or use to make sure it runs.
Re: Need mags for C-65 or C-85
Post by John Fenner » Wed Apr 18, 2012 1:11 pm
What type mags? Open them up and clean them with a strong degreaser to get the rust and grime out, blow them out real well and dry, retime and reassemble them, then open up and polish the points with a fine wire wheel to get the corrosion off them, set them and try firing them on the bench, if they fire run the engine with them, then overhaul the mags with new parts or replace them.
I would hope they are Bendix mags.
JimC
Post by JimC » Sun Jul 08, 2012 7:02 am
Continental never made a C-65.
Do you mean A-65?
dusty burch
Post by dusty burch » Sun Jul 08, 2012 2:28 pm
well gee the last time i checked it jas to have spark to even run
