Prop for Angle Valve 200 Lycoming
SwampNinja
Post by SwampNinja » Sat May 19, 2012 3:21 pm
Larry wrote:You can get a Q series in a 66" length......
If I decide to go with the same engine stand I will just go with a 66" q series with some extra pitch.
I am here: http://tapatalk.com/map.php?w3plu4
"It is what it is."
CAPTAIN-D
Re: Prop for Angle Valve 200 Lycoming
Post by CAPTAIN-D » Sat May 19, 2012 6:58 pm
I may try the short hub to make my Q 70"and see how that works.It just seems that most of the post on here state that the Q may be a little too wide for the 4 cylinders.
fl cracker
Post by fl cracker » Sat May 19, 2012 7:12 pm
Captin, I ran a 70" Q on my 4 banger for 2 years. All around great prop, I found the NGH to have a better mid range, quieter , and a better top end. IMO I would not go down to 66" because it is going to effect the cruise!
" I have two guns...
One for each of you "
2017 Al David / stroked LS
dantheairboatman
Post by dantheairboatman » Sat May 19, 2012 8:12 pm
My brother had a 66q on 180 and it was very flat. I would not go below 68 if you can help it. Capt. Just let me know I can send you a 70"Ngh and you can use the short hub to test your 70q against the Ngh .
Sensenich propellers dealer.
Airboat consulting.
Dan@352 812 2239
Larry
Post by Larry » Sat May 19, 2012 11:58 pm
What do you mean by very flat? Are you talking pitch wise? I have a friend with an angle valve 290 with a 66 Q and he loves it.
fl cracker
Post by fl cracker » Sun May 20, 2012 12:35 am
Q props tend to fall off on the top end!
CAPTAIN-D
Post by CAPTAIN-D » Sun May 20, 2012 9:45 pm
Darren at sensenich told me he thinks they have used a short hub that I can swap for my medium hub.I will be able to try the NGH and the Q to see which one works best at 70".When I do this I will post what I find.
abuchanan68
Post by abuchanan68 » Mon May 21, 2012 8:51 pm
I run a 68" Q on my 180 Lycoming. Had the H before, it sucked!!! but the Q brought it to life!! Great prop for my set up. :thumbleft:
abuchanan68
Post by abuchanan68 » Mon May 21, 2012 8:53 pm
SwampNinja
Post by SwampNinja » Mon May 21, 2012 11:32 pm
abuchanan68 wrote:I run a 68" Q on my 180 Lycoming. Had the H before, it sucked!!! but the Q brought it to life!! Great prop for my set up. :thumbleft:
Have you tried an ngh?
"It is what it is."
SwampNinja
Post by SwampNinja » Mon May 21, 2012 11:33 pm
CAPTAIN-D wrote:Darren at sensenich told me he thinks they have used a short hub that I can swap for my medium hub.I will be able to try the NGH and the Q to see which one works best at 70".When I do this I will post what I find.
Pls let me know how the testing goes.. Very eager to know the difference between ngh and q. Thanks.
I am here: http://tapatalk.com/map.php?0rad21
"It is what it is."
HomesteadGator
Post by HomesteadGator » Tue May 22, 2012 10:47 am
I had a 200av with a 70'NGH on a 12x7 hancock sled (the yellow hull/orange rigging one up for sale recently)..the NGH was a great prop for that set up, you could run on a plane with a passenger at 1200rpm and have a conversation.. it would run up and down the hill np with two people, and as for top end the boat clocked out at 71 in skinny water on the gps...i had it pitched at 2..
FTD RACING
CAPTAIN-D
Post by CAPTAIN-D » Tue May 22, 2012 3:25 pm
Talked to Darren at Sen.I will be sending him my hub later this week and he is going to seen me a short hub.I will try the Q and NGH and report my findings.Will take a week or so befor I try both props.
SwampNinja
Post by SwampNinja » Tue May 22, 2012 6:13 pm
HomesteadGator wrote:I had a 200av with a 70'NGH on a 12x7 hancock sled (the yellow hull/orange rigging one up for sale recently)..the NGH was a great prop for that set up, you could run on a plane with a passenger at 1200rpm and have a conversation.. it would run up and down the hill np with two people, and as for top end the boat clocked out at 71 in skinny water on the gps...i had it pitched at 2..
I spoke with you earlier. i need a new engine stand to fit a 70" ngh.
"It is what it is."
SwampNinja
Post by SwampNinja » Fri Jun 01, 2012 11:11 am
Any word yet Captain D?
"It is what it is."
todd glover
Post by todd glover » Fri Jun 01, 2012 2:20 pm
I vote for 66 I've run north of 90 mph on a lite alm boat but who knows I've never tried a long prop didn't think they would snap up the same
CAPTAIN-D
Post by CAPTAIN-D » Sat Jun 02, 2012 9:32 pm
Sen. mailed out the short hub Friday.As soon as I get it I will try the Q and see how it performs .When I pulled my medium hub off to swap out for the short hub i put my 68" Cypress on and did at test.Hole shot in deep water 60 yards 32 MPH.Cruse speed at 2000 Rpms deep water 23 MPH.WOT deep water 38MPH.Break free on dry ground 2200-2300.This was done little or no wind.93 degrees high sun no moisture on the ground.It will be interesting to see how the Q and NGH do.Engine is turning 2800 RPMS WOT.
SwampNinja
Post by SwampNinja » Sat Jun 02, 2012 10:00 pm
Thanks for the info. Can't wait to see your progress.
I am here: http://tapatalk.com/map.php?szrqck
"It is what it is."
scottymartin
Post by scottymartin » Sun Jun 03, 2012 6:57 am
I run a Q-68", on my O-360- 12' Scorpion. A lot of pitch. 2 1/2. Great push, cruise at 1600- 2 people, gas is around 4 1/2 gals a hour. Truthfully, I wouldn't want it any faster for topend, I'd have to call the control tower.
Little Bear 12' Scorpion w / O-360 200hp
hmgm123
Post by hmgm123 » Sun Jun 03, 2012 9:20 am
CAPTAIN-D wrote:Sen. mailed out the short hub Friday.As soon as I get it I will try the Q and see how it performs .When I pulled my medium hub off to swap out for the short hub i put my 68" Cypress on and did at test.Hole shot in deep water 60 yards 32 MPH.Cruse speed at 2000 Rpms deep water 23 MPH.WOT deep water 38MPH.Break free on dry ground 2200-2300.This was done little or no wind.93 degrees high sun no moisture on the ground.It will be interesting to see how the Q and NGH do.Engine is turning 2800 RPMS WOT.
What motor do you have?
southernman13
Post by southernman13 » Sun Jun 03, 2012 9:21 am
I run the 72" wt wide or regular blade on my 200av. I had a 72"Q and it performed well but the wt is better on my setup. If your 180 or 200 won't turn the 72" Q then your motor ain't very strong IMHO. I tried the cut down blade wt to make it a 70 " and wasn't impressed at all. Also tried the narrow blade w/t and wasnt impressed at all. It was snappy but went flat after about 2200 rpm and I tried many settings. The longer the better IMHO. 2 other buddies 1 has a runout 180 running 72"Q on 2 mark, runs great. Other buddy has a 190 av carbed motor, fresh rebuid, he has. 70"Q it doesnt do any better or as good as the 72"Q on the 180 boat.
CAPTAIN-D
Post by CAPTAIN-D » Sun Jun 03, 2012 1:39 pm
I have a Lycoming Angle valve 200.I didn't say the engine couldn't turn the 72" Q but that it seemed to go flat in the upper RPMS.It had a lot of push down low on the ground,and cruised 1800-1900 RPMS in deep water.From what I have seen there are a lot of 0-540 260hp running the 72".Thought I woud try a 70" on my rig to see how it performs.And by doing this I can also try the NGH.By running the short hub it gives more options to try.If I don't like what I find I can always go back.I like the idea of being able to try different props to see which one works best on my rig.
fl cracker
Post by fl cracker » Sun Jun 03, 2012 3:15 pm
A 72" is a little to large for a 180. I would stick with a 70" and put some pitch in it!
todd glover
Post by todd glover » Sun Jun 03, 2012 4:47 pm
66-68 and get out to 3a and some needle grass and let her eat I stopped in a burn with me a friend and my son 68 inch prop and pulled right out and most important toe she will flat out run
SwampNinja
Post by SwampNinja » Sun Jun 03, 2012 8:25 pm
68-70" is the ideal prop size for a 4 cyl. That's from a lot of people in the business I've been talking to.
I am here: http://tapatalk.com/map.php?ug1gma
"It is what it is."
