Prop for Angle Valve 200 Lycoming
schmidtav2
Site Supporter - VII
Re: Prop for Angle Valve 200 Lycoming
Post by schmidtav2 »
Just ran my new boat this past weekend, a 12' Bullfrog Marine glass hull with a 200 hp Lycoming put on a 70" narrow whisper tip turning 2900. It performed great, lots of snap, low end push, and top end also. I'm going to try a 68" Q series to compare but I think the narrower blade may work better on the 4 cylinders.
R L Williams
Post by R L Williams »
Yep, waiting to hear how the Q compares, I have a cyprus 68" good push, but I need something quieter. I'm looking at WT, NGH, Q.
Dont want to lose low end grunt, dont need speed, just quiet.
"GRASS SCOOTER"
Member of the over the hill gang.
United Sportsmen Airboaters Alliance.
NRA life member.
techelp3215436655
Post by techelp3215436655 »
CAPTAIN-D wrote:I am thinking about trying the 72" Wisper tip Narrow on my boat.I have a 72" Q on there right now.Looking to find out what you guys are running.
Anybody running the Wisper Tip on their boats? How do you like the performance.I guess I would like to know if I would see a performance gain or not.Thanks
I have used that prop on several different boats and engine combinations the 'Q' is great they left some on the table, W/W produced there whisper tip long after the 'Q' was out, W/W noticed the snap needed to be quicker than it was to help break the boat loose, quicker snap means engine will get to top rpm faster, also they worked on more mid rpm. thrust, for increased cruise speed there all way's perfect balance yes I be live you will get a little but is it worth the difference, may be may be not but I am sure W/W would sell you the prop free delivery no tax out of state, 30 day's trial time if not enough difference send it back at your expense free tec8668075354
fl cracker
Post by fl cracker »
RL, have Dan set you up with a 70" NGH. Very Quiet, Best all around prop on my 4 banger to date!
" I have two guns...
One for each of you "
2017 Al David / stroked LS
SwampNinja
Post by SwampNinja »
I'm going with a cypress 68" possibly 70" prop.
I am here: http://tapatalk.com/map.php?4jxf52
"It is what it is."
moondog2020
Post by moondog2020 »
70 inch Q series. Final answer. Best prop ever
LYCOMING
SwampNinja
Well see!!!
"It is what it is."
CAPTAIN-D
Post by CAPTAIN-D »
CAPTAIN-D wrote:Sen. mailed out the short hub Friday.As soon as I get it I will try the Q and see how it performs .When I pulled my medium hub off to swap out for the short hub i put my 68" Cypress on and did at test.Hole shot in deep water 60 yards 32 MPH.Cruse speed at 2000 Rpms deep water 23 MPH.WOT deep water 38MPH.Break free on dry ground 2200-2300.This was done little or no wind.93 degrees high sun no moisture on the ground.It will be interesting to see how the Q and NGH do.Engine is turning 2800 RPMS WOT.
Ran the 70" Q Friday and this is what I found.Hole shot 60 yards 32 MPH deep water.Cruise 2000 Rpm's 25 MPH.Wot deep water 38 MPH.Break free on the ground 2100-2200 RPM.I thought it was interesting to see that in 60 Yards and top end WOT the 68" Cypress and the Q ran the same.On the ground is where the difference was.When the boat broke free with the Q it would crawl around on the ground with less RPM"s than the Cypress did.Also ran both props from a stand still up a steep levee .The Cypress made it about half way.The Q made it all the way to the top.By the way when I had the 72" Q on the boat it only made it half way up the levee. I set the 70" Q turning 2700 RPM"s.It will be interesting to see if I gain anything wih the NGH.
SwampNinja
Damn. Im about to put a Cypress on my boat. I wonder if I should just go with a signature.
"It is what it is."
hmgm123
Post by hmgm123 »
SwampNinja wrote:Damn. Im about to put a Cypress on my boat. I wonder if I should just go with a signature.
I thought the cypress was the same prop as the signature just shorter? Maybe Plum will jump in and clear this up.
BlowInIt
Post by BlowInIt »
The Cypress blade is shorter and Narrower compared to the Signature. It's hard to beat a Cypress for a 4cyl or a signature on a 6cyl. I just wish the quality was a little better.
scottymartin
Post by scottymartin »
Running a 68" Q on my 200. Love the low end push.
Little Bear 12' Scorpion w / O-360 200hp
SwampNinja
BlowInIt wrote:The Cypress blade is shorter and Narrower compared to the Signature. It's hard to beat a Cypress for a 4cyl or a signature on a 6cyl. I just wish the quality was a little better.
Yep
I am here: http://tapatalk.com/map.php?lfg4mb
"It is what it is."
jimmyflfr
Post by jimmyflfr »
Cypress is the same as the signature just shorter. Cypress for 4 cylinder signature for 540 and dd caddy.
BlowInIt
Post by BlowInIt »
^^^^ That is incorrect info! The cypress blade is a narrower blade as well not just shorter..... Just as I explained a couple posts up.
SwampNinja
This should help Jimmy.
"It is what it is."
Tony480
Post by Tony480 »
Deffinatley not the same. :wink:
scroggins44
Post by scroggins44 »
Honestly I'm tired of sending my ngh back to have the winglets redone....this is the 4th time in less then a year.I'm over it anyone wanna trade for a q?
fl cracker
Why do they need to be redone?
SwampNinja
scroggins44 wrote:Honestly I'm tired of sending my ngh back to have the winglets redone....this is the 4th time in less then a year.I'm over it anyone wanna trade for a q?
A lot of people don't know this.
I am here: http://tapatalk.com/map.php?zcdgfz
"It is what it is."
scroggins44
Cause the tips keep getting burnt every about 20 hours or so
Larry
Post by Larry »
What if you ran it with no winglets?
scroggins44
Then what's the point in having it? This into the first time I've said this on here about the ngh but sinsenich needs to design a full leading edge
fl cracker
Mine looks as good as the day i picked them up with a lot more running
time than that. I would have thought they would have giving you a new set of blades.
scroggins44
They sure haven't the blades look like shit where the leading edge stops then picks back up at the winglet there is even enough room under leading edge to stick a ball point pin head under the winglets leading edge.this is the 4th time I have had to send it back for them to repair it granted I did sling a bolt through the main leading edge the first time never even touch winglet
