need help starter is messing up
bones21
Post by bones21 »
Hey guys went out 2 days ago for the first time and boat did gd. It is a lyc 125 and now the starter is messing up it will engadge but makes a loud noice and prop don't turn any help would be greatly appreciated this weekend is my 21st and would love to be on the lake thanks in advance for any help
Bangin6
Re: need help starter is messing up
Post by Bangin6 »
It sounds like the starter is skipping on the flywheel. Check in the tech or aircraft only sections, prob find similar happenings.
12' hamant, single mag 220 gpu, Sensenich 2 blade NGH. Working on the a/v conversion.
I don't like jail, they got the wrong kind of bars in there -Charles Bukowski
Post by John Fenner »
Or the one way roller clutch (sprag) is shot, what type starter do you have?
dusty burch
Post by dusty burch »
if it is the dodge starter get a starter for a v8 dodge truck for a 1990 or up 318 or 360 the v6 starter is the same it has a little smaller motor is the only difference
Steve Hall
Post by Steve Hall »
I HAD THAT PROBLEM WITH MINE AND IT WAS THE STARTER BRACKET OUT OF ALINMENT AND WAS NOT CATCHING THE FLY WHEEL RIGHT PULL THE STARTER NOSE GEAR OUT WITH YOUR FINGERS OR PLYERS AND SEE WHERE IT LINES UP WITH THE FLY WHEEL. If you are near Osteen i can help you with it.
air-roberts
Post by air-roberts »
it sounds like to me that the Bendix is bad. has that starter been on there on worked if so it's you Bendix and yes it's replaceable. if your from around here i can repair it if not find a starter and alternator repair shop and they can unless you have a lifetime starter in which just replace it
Air-RobertsImage
New & Used PROPs
WhirlWind prop dealer
